Question about Janome D'cor Excel 5018
Handwheel freewheeling the handwheel is freewheeling and not connecting to move the needle holder manually
  • 248 Answers
It could be the gears of your handwheel try spraying it with wd-40.
is it making any noise?
Posted on Jun 25, 2008
How do i get the needle to stop moving when winding the bobbin?
Most machines will have a smaller wheel inside the handwheel that you turn towards the front of the machine, while holding the larger outer handwheel. If the needle still moves after doing this you'll need to work oil through the handwheel bushing.
Dec 04, 2016 | Sewing Machines
Handwheel does not rotate completely
Have a solution but need to know the model. SewTechnical Home ">
Jan 08, 2014 | Bernina Sewing Machines
Tesco ej09 sewing machine - handwheel wont turn
I actually had the same problem, it turned out that after threading a bobbin I'd forgot to slide the bobbin holder back into place (just push it to the left) Hope this helps
Apr 14, 2012 | Sewing Machines
Belts intact, press on pedal, motion in belts, but not on needle end
does the needle go up and down when you turn the handwheel by hand? if so, one of the belts may be slipping - tighten it enough to make it grab.
if the handwheel does not make the needle go up and down, is the handwheel lock for bobbin winding un-locked? if so tighten the handwheel lock inside the handwheel. if the handwheel lock is tightened and the handwheel spins when motor runs the handwheel lock is asembled incorrectly. if this is the case, undo screw in handwhhel lock nut and spin lock nut off machine, then remove pronged washer and turn 1/3 turn and re-install.
Jul 23, 2009 | Brother LS-1217 Mechanical Sewing Machine
Viking 936 Serger- handwheel will not turn properly
hi there,
this type of problem related to "overload protection" the motor can't overcome the load work,then it would able to stop your machine,theres problem on motor assembly try to check the carbon brush.if worn out replace,handwheel are couple to motor pulley inside machine.there an opening for the belt.if you want to check it loosen bolt cover,have move the belt you can figure why handwheel moving tight.if you realease the belt handwheel will move independently but handwheel is connected to a cam shaft w/mechanical link connected such as gears,cam and bushing that
can also suspiciuos of obstruction can came there.take this to service center if trouble link to mechanical problem.have a nice day
rate me and thank's
Apr 19, 2009 | PfaFF Hobby 4260
Singer Model 5050 Timing Problem
Actually,timing of needle vs, shuttle is not very easy job several factor you should check on.There is belt ot sometime a shafting with worm gear and helical gear under machine w/c drive the shuttle with the bobbins in timing order,Any one of them is present on the timing adjustment can be done by releasing the belt or the helical gear,besure machine is unplug then set all mechanism on low dead center meaning the needle move to utmost lower position catching this by the shuttle and bobbins at center position.No motion applied if this was set up,engage the belt with pulley and the bobbins link holder tigh allenscrew besure the needle is lower dead center at the center of shullle bobbins catching needle without motion when setting back at original position.If this was made manually move it on handwheel going up and side down the needle gradually if the needle move freely several time and it was catching this by the shuttle hook bobbins.if ok put thread bobbins and upper thread dial tension with the needle.Move machine on handwheel try to catch the bobbins thread,If this so your machine is ready to sew again if problem occurs on alignment repeat adjustment on perpect alignment,besure all parts on upper casing of machine specially two drive gear are in normal alignment.
Mar 15, 2009 | Singer 5050 Mechanical Sewing Machine
Handwheel doesn't move needle
Sounds like the connection between the handwheel and the needle as disconnected (needle bar). It appears from the picture that this is a version of a mass-market product geared for kids/very light duty sewing.
If so, you may be able to reconnect this by removing the side-cover or top-cover of the machine (if removable). The problem is going to be re-timing the needle with the hook/bobbin assembly.
If you are unable to reconnect or get the timing correct, a good local machine dealer/repair tech should be able to take care of it for you. Unfortunately, the cost of having a technician fix may be way more than you want to pay or the machine is worth.
Best of luck with your repair,
Kim & Linnette
Jul 30, 2008 | Barbie 11301 Mechanical Sewing Machine
Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Mar 31, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
154 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
