Question about HP LaserJet 4mv Printer
Will not print.
Printer is showing 50 service
  • lrobb316 Jun 25, 2008
    thanks for the fast response. to my service problem.
    Novelist:
  • 121 Answers
Theproblem sounds like the fuser assembly. Here is a link explaining on how to check it that contains a tutorial with pictures:
Link
Good luck and keep me posted. If you thought this solution was helpful please rate it when you get a chance. Thanks - Tech101
Posted on Jun 25, 2008
  • 667 Answers
Hi lrobb316 - 50 Service Errors are symptoms of a fuser malfunction. They may indicate either an improperly seated fuser or a defective fuser. Turn your printer off for 20 minutes and then turn it back on. This may correct the error. If not it will require service. Thanks.
Jeff
  • 818 Answers
LaserJet 4V ***If it is intermittent or can be cleared by shutting it off to let it cool. The fuser is running too hot, order rebuilt.***
Notes to remember!!
  • The low voltage power supply is what the takes the 110v ac from the outlet and is for this reason often mistaken as the high voltage power supply. The high voltage power supply HVPS main purpose is to charge the toner cartridge with a much higher dc voltage.
  • Always Remove Power from the printer before working on it!
  • Lamps can break in shipping or if the fuser is dropped.
  • The fusers use floating connectors don't force them in.
  • Sergio Scalfaro
    Sergio Scalfaro Jun 25, 2008
    BX Fuser Measurements
    If
    you measure values in the indicated range on the right hand side of the
    fuser, the lamp is fine (240V fusers will read 3-4 times higher on the
    right hand side).
    Models
    HP LaserJet 4V/4MV (Check our cross reference guide for other brands)Removal Instructions
    Open
    the front of the printer. Pop out the charge transfer roller, being
    careful not to touch the surface of the roller. Handle it at the metal
    ends only. Remove the 5 big brass screws holding the fuser in. There is
    a screw at each lower end of the fuser. At the top of the fuser, you'll
    see 5 screws. Remove the 2 outboard and the center screws. While
    pulling out on the plastic side to clear the metal shaft, lift one end
    of the fuser up, repeating for the other end.
    If you don't have a
    meter, continuity can also be checked across the contacts on the right
    hand side of the fuser by using a digital tester.
2 Suggested Answers
POCBM
  • 121 Answers
SOURCE: cannot reset code 50 for service
50 error is the fusing assm. You need to replace the fuser then the error will go away.
hope this helps.
Posted on Mar 23, 2009
I have a Hp Laser 4 printer it is always showing 50 SERVICE and it is not printing . Please help me to solve this. Thanks. VIJAY
you have a problem either in the fuser assembly, or in the DC power supply, try to fix this printer, IT IS GREAT..........
Apr 03, 2010 | HP Office Equipment & Supplies
HP 6310 All-in-one printer
hi friend
u need to do service on ur printer u have problem in ur roler or a gair box so u have to show your printer a good service man & u have to pay for it 20$ to 50$ for service
Apr 07, 2008 | HP Officejet 6310 All-In-One InkJet...
Shows 50 service in printer window
ok its either going to be your psu unit or your fuser.... if its showing the 50 service and doesn't print anything I would definitely replace the fuser... here is a link with some more information on the matter... http://www.fixyourownprinter.com/kits/hp/K05
Jan 06, 2010 | HP LaserJet 4 plus Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Won't print black even though shows as 50% full
Print heads may be clogged. Other carts may be empty, some printers will not print if any carts are empty.
May 07, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Cannot reset code 50 for service
hope this helps.
Mar 23, 2009 | HP LaserJet 4 plus Printer
I have the same problem. Most people i asked about it said it is a mechanical problem. It's better to bring it to a brother service center near you.
Feb 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
HP LaserJet 4mv Printer Logo
148 people viewed this question
Ben Johnson
