Question about ASUS P5P800-VM Motherboard
Install VGA driver
Hi, I wanna ask about VGA driver installation. I cannot install it from the CD. Always said that 'one or more files required for installationare either missing or corrupt'. How to solve this problem? Thanks.
(Fita)
  • Anonymous Jul 23, 2008
    one file missing
I am facing the problem in bios and in os installation, when the os is compleate the installation will shoutdown autometecaly it wornt be the restart, when system is on it show the press the f1 key to contune
Posted on Jul 08, 2008
Hello! Im having difficulty installing windows 7 Operating system on my R439 samsung laptop, everytime I boot it, it's always asking for "drivers to be installed first", so i can't continue...
Hold down F1 key at boot-up to get to BIOS rather than booting up with CD in CD reader. Switch to download drivers or boot from the CD rather than the HD.
Apr 01, 2017 | Samsung Computers & Internet
I wanna the cd of x300 Xtenda multibox because I need the driver and cd for the installation
I would recommend NOT using the CD. Uninstall any current version of vSpace. Reboot. Makesure you have no missing or conflicting device drivers inside of devicemanager. Then run the NComputing cleanup utility located here:www.nc-eng.com/tools/ncuninstall.exe. Download current version for XP(v4.03.104.1) from here: www.ncomputing.com/download/x300. Unpack the.ZIP file and install. Reboot and register.Do NOT, I repeat, do NOTinstall from the provided CD and upgrade. Simply install straightfrom the download file I provided in the link. Lastly make SURE you REGISTER the CARD and the XD1 boxes.
Sep 29, 2010 | NComputing X300 3 User Expansion Kit...
Sir how could i install my pc vga and sound drivers
Hi, just install the CD installer of the motherboard and then look for the existing vga and sound drivers. Double-click on the icon for the downloaded file, then follow the instructions after downloaded the driver, restart the computer, that's all. Feel free to ask whatever the result.
Regards;
VOTIT
Jun 29, 2010 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
How to install the driver
For driver installation you should have driver CD or setup file of driver.
If you have CD then do the following steps :
Put CD in cd drive and open the CD, in CD you will find a file which name is setup, just double click on setup file. Whenever comes a prompt and ask for "next" then click on "next", at last you will find finish, just click on this button. Driver will install.
Regards
Ashly
Feb 04, 2010 | KWorld PlusTV (ATSC-115) (KW-ATSC-115)
How to install cameras to computer
Whenever you connect a new peripheral to your pc it detects it and tells you that it has detected a new hardware and tries to install necessary driver files for it. If your OS is not having necessary files it asks you to insert the drivr CD. In order to let the OS know what is configuration of the H/W .ini file is required which remains in the driver installation CD. You have to show the path to the OS where the .ini file is located. If the PC does not detects the camera on Plug n play then you can go to control panel camera and scanners and add a new one over there once asked for driver you have to give it a path to the installation CD. Now a days vendors do not give away open drivers they put it in autoexe cab under this situation you should not connect the camera to the PC untill you run the exe or setup file in the installation CD after running it you can connect the camera and windows will detect it. Hope this solves your prob. If any further assistance required kindly ask.
Jun 14, 2009 | QPS QSIPBL2 Network Camera
I wanna change my onboard vga with new AGP vga ,,,
Thats easy when your looking at the front of the case unscrew the left hand panel.(2 screws on the back) Now look at the agp slot its the one closest to the power supply. Punch out or unscrew back back blocking plate where the card pokes out. (Great cut warning on that if its the punchout type never use your hands! Always use a tool! They cut real bad!)
Now earth youself on the case by touching it before touching the card. Slip the card into the slot and screw it into the back plane on the top. Once the card is installed fit the side cover back on. Now plug the VGA D shaped connector (15 pin) into the back of the new video card. Now your ready to start up the machine. While the computer is booting with the new card insert the driver cd that has come with the card. When windows boots just follow the prompts and it will install the drivers. Its as simple as that. When you install a new card you don't need to remove the old one because its a part of the motherboard. The motherboard realises that you have a new card in and it uses that instead.
Don't forget to rate me!
Cheers
Apr 06, 2009 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
MB Foxconn 661M03-G (s. 478) problems with IDE/ATAPI controllers
Hello uxmal,
The Drivers of 661M03-G
On-Board VGA Drivers: Click Here
AGP Drivers: Click Here
On-Board Audio Drivers: Click Here
BIOS File: Click Here
Thank you for using FixYa.
Mar 08, 2009 | Foxconn 661M03-G-6EL Motherboard
Question Mark in My Device Manager
dear,
pl install 1st chipset dirver from motherboard cd.2nd install vga/video driver,audio driver,ethernet/lan driver.
when require restart pl restart pc.
Feb 28, 2009 | Acer AOpen AW 724 Sound Card
Intel 865 graphic drivers for windows 7
hi there
as windows 7 is still in beta stages most drivers are not available for it yet......
are you running the 32bit or 64bit version ??
i ask this because either version is compatible with windows vista so you could try obtaining these drivers from intel.......
hope i helped
Feb 23, 2009 | Intel D845GVSR Motherboard
Hi!
Hi there.
If you are looking for Computer software relevant to your Phone, goto www.sonyericsson.com/cws/support/softwaredownloads/detailed/pcsuite/k750i This will point you towards the latest version of Sony Ericssons PC Suite Which will enable you to hook up your phone to your PC to transfer files & Contacts etc !
Hope This Helps ?!
Oct 27, 2008 | Sony Ericsson K750i Cellular Phone
ASUS P5P800-VM Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
