Question about AudioBahn A2200HCT Car Audio Amplifier
Red Status Light
Ok...i have an a2200hct amplifier, it powers on, i have everything connected right..it's grounded well, but yet the red light comes on in between my meters! i opened it up and looked for any burns,cracks,or noticable differences on the compacitors and board,but didn't anything..So please just throw me some options i can go through?thanx
  • 631 Answers
The most common cause for the protection LED to be lit is shorted output transistors. I'm not familiar with that amp but if you can send me some decent quality photos of the insides, I can tell you what to check.
You should only continue if you intend to replace the defective transistors yourself.
babin_perry@yahoo.com
Posted on Jun 25, 2008
I have a 1990 Celica, trying to put in new radio. Got everything wired up correctly, Constant - blue/yellow, acc - gray, ground - brown and it won't come on. Radio fuse (top center 15 amp) is good,...
You have it right. Use a 12 volt test light to see if there is power between the gray and brown wires when the key is on. If there is power there, you may have got hold of a bad radio.
1990 Toyota Celica Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow, connects to yellow
Radio Switched 12V+ Wire: Gray, connects to red
Radio Ground Wire: Brown, connects to black
Radio Illumination Wire: Green, do not use
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Oct 29, 2011 | 1990 Toyota Celica
I have my amp hooked up right to two 12 inch subs but the red protect light comes on wht does this mean?
Check all your cable work.
Power is connected tight? Ground is attached tight - on both ends (my guess is it is the ground) Remote cable?
Is the ground a proper ground?
Mar 01, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
Ok so my Nitro BMW - 481 2000w amp was working and then i came back the next day and the red protect light was on its been working for weeks but now it has the red light.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. ok-nitro-bmw-481-2000w-amp-working-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Mar 17, 2010 | Nitro BMW-481 Car Audio Amplifier
Power light turns red
Make sure the red, yellow, and remote cable (usually blue and white stripes) that are coming from the radio are connected to the correct positions in the amp. Make sure amp is also grounded well enough that the ground cable does not come loose. make Sure none of the cables touch each other or the frame of the car (except for ground). Also make sure the cables for the speakers are connected to the amp and subs/speakers properly and not touch any part of the amp or other cables. Check the cables then write again if it happens again.
Sep 28, 2009 | Hifonics Brutus BXi 1206D Car Audio...
When just wblue wire is connected red light comes on
This sounds normal. The light comes on when there is 12v supplied to the blue wire (remote input). Need more details. brian.small@bobstgroup.com
Sep 13, 2009 | Pioneer GM-5200T Car Audio Amplifier
Protection light just blink on and off
check that your ground wire is connected properly to both your amp and body of vehcile you may need a thicker earth wire
Mar 23, 2009 | Power Acoustik LT-980/2 Car Audio...
Red amp light
some parts are damaged ,maybe audio amplifiers IC´s or power fet´s
Mar 16, 2009 | Insignia 600W Bridgeable Amplifier with...
Amp light is neither green or red
have u connectted the remote wire from head unit to turn amp on? have u got + and - the rite way round.hope this of use.
Mar 05, 2009 | Power Acoustik PS2-1250 Car Audio...
Mine is actually a q4000 4 channel amp
First of all, you MUST HOOK UP YOUR GROUND WIRE FIRST. You may have damaged it if you hooked your power and trigger wire first and then the ground wire. Unhook EVERYTHING except the hot wire, ground wire and trigger wire. If you still can't get the unit to come on then it is time for a trip to the repair shop. Good luck.
Feb 01, 2007 | Cadence Q200 2 CHANNEL POWER AMPLIFIER...
AudioBahn A2200HCT Car Audio Amplifier Logo
69 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Josh Whitehead
Josh Whitehead
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
