The problem is your Vats security system. This causes the car to either "not start" or "shut down" while running. (depending on the system) If the security light flashes, i guarantee that this is what the problem is. 1st trick, turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start. Cheap fix: ----- http://vats.likeabigdog.com/ ----- Bypassing the key Never worry again fix: -------- http://newrockies.ca?ap_id=judd0081 ----- With this fix, you can take that whole Vats, passlock, passkey **** system out of your car all together. Good info on both sites
