Question about RCA Scenium D40W20 40" Rear Projection HDTV
Rca d40w20 rear projection tv with popping noise
I had this tv for a year and then a random popping noise and a flicker of the picture would happen at the same time very randomly. never could get it to reproduce consistantly. I have had 3 technician calls and they replaced a high voltage board twice and the third time the tech stated to leave off the front cover and pay attention to which of the 3 tubes flicker when the popping noise happens. reluctantly I did it but could never see which tube did it because it happened so randomly. that repair company gave up.
anyone else having this problem. its just never consistant, would happen 3 times in one day then never happen for a while then would pop again. luckly i bought a 3 year warranty (has paid for itself) and its up in august and would like to get this fixed!!!
  • 979 Answers
It sounds as if you have a grid to anode short that is inconsistent. I would try to get the warranty company to just go ahead and replace all three tubes and be done with it. But, this is only my opinion, and past experiences with these sets. An aside; the more brightness level you ask of the tubes, the more this can be aggravated, as a general rule. Try different sources and program content and see if this is the case. Those scenes with more luminance (brightness) will stress the tubes more than low-level or dark scenes. See if that helps...accordianman
Posted on Jun 25, 2008
We have a 14 year old rca scenium that the picture looks like a paint by number,what can i do to fix this? thanks
If your RCA TV is 14 years old, it may be nearing end of life. You may find repair is not worth considering.
Sep 10, 2014 | RCA Scenium D40W20 40" Rear Projection...
When i turn on my tv it lights up the on and off button but nothing else happens, no picture, the it turns off and back on again.
At the back... small door.. remove old bulb and replace it with new. It could be blown and it is protecting the rest of the TV
On google put: RCA D40W20 parts.
Near the top will be a site to go to and they will ship to you and it is easier than changing a home lightbulb
Aug 09, 2010 | RCA Scenium D40W20 40" Rear Projection...
It makes awhisling noise
Whistling and whirring is usually related to the color wheel. Does your TV have good picture still?
Feb 05, 2010 | RCA Scenium D40W20 40" Rear Projection...
I have an RCA D40W20 tv. I have the vcr/dvd connected to the video 1 jacks. picture will not format to screen. everyones heads are cut off. picture is too tall. any fix?
Ty using the zoom settings on the TV or the dvd player, also check the inputs by testing the tv with free to air or another input to determine if its the tv or the dvd player. Good Luck.
Nov 27, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Mar 29, 2009 | RCA Scenium D40W20 40" Rear Projection...
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
RCA Scenium D40W20 40" Rear Projection HDTV Logo
66 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
