Question about Kitchen Ranges
Kenmore Elite Range/Oven problem.
When we activated the Flex-clean button on the control panel to self clean the oven, it was going great for about an hour and then and F10 ERR message appeared on the panel. There was a beeping sound as well. We couldn't turn it off so we had to disconnect the power. What does F10 ERR mean? We have an elite glasstop electric range that is only 25 months old. at 6 months after purchase the circuit board had to be replaced and now 18 months later we are having the same problem with a F 13 error and unable to use the oven just a month outside of warranty. figures. I have gotten no help from Sears and there is nothing in the manual to aid in trouble shooting. I believe there is something faulty in the circuit boards as that I have a reasonable expectation that a range should have a much longer lifespan than 18 months. I think the replacement of the board could cost several hundred dollars. I would like to know what F 13 means, the last repairman didnt even know.
  • 1 more comment
  • laurieg215 Oct 01, 2008
    I received an F13 error - there is no info in the manual - it says to call Sears. Sears will not give the error code information without sending a technical out first. The oven will not work.
  • Anonymous Feb 17, 2009
    I have a Fridgidaire PLES389ECG with an F13 error code when you put it on broil. Help
  • jtracy15 Mar 16, 2009
    I have the same problem. Error message when it was cleaning and now it won't stop beeping until i turn the power off. I see no feedback about any of these problems,
We had this problem as well, our's locked and we were not able to unlock it.
We found that holding down the stop/clear button on he bottom right of the key pad for 3 consecutive seconds releases the lock.
The locked oven wording will blink for about a minute and then the oven is released completely.
So frustrating...I accidently hit the option while cooking. Talk about panic. I needed to use the oven.
Posted on Oct 21, 2008
  • Dingy Blonde Nov 08, 2010
    F13 on my Frigidaire shows to replace the UIB , however I found on the US Consumer Report page that there are many recalls on the Frigidaire Ranges. I am currently waiting on a return phone call from the liability department.
Not sure how to spell this but i believe the orface on my kenmore elite gas stove needs adjusted. If i set it over 350 degrees it will not work. We changed it from natural gas to propane. Can anyone help?
Posted on Sep 26, 2008
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Oven door is locked out - Sears no help
      1. Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
      2. Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
      3. Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jul 03, 2015 | Kenmore 30" Freestanding Electric Range...
Lost my oven control guide. how do I set the self clean function on the kenmore elite dual fuel range
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 04, 2011 | Microwave Ovens
Pressed the Clean Button
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Jul 16, 2010 | Kenmore Kitchen Ranges
Kenmore elite oven lock
None of above worked for me. But, gave me a clue. I pressed the Stop/Clear button for apprx 10 sceonds. the "door locked" flashed for 5 seconds and then cleared and the door unlocked. Panel worked fine after that.
Mar 10, 2008 | Tappan TGF320 Gas Kitchen Range
Kenmore Elite Electric Range, Display stuck on LOC
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Feb 03, 2008 | Kitchen Ranges
My kenmore glass top stainless steel slide in range has an error message code F93. I was attempting to allow my range to self clean when this err message appeared. Now I can't get the door unlocked. Help?? We've had a lot of problems with this range. We've had the service tech come out probably 4-5 times for different things. I think I got a lemon. It just turn a year old-we extended the warranty . I've called to complain but I got no help. They said it had to be for the same problem each time. Even the tech said the oven was a lemon but he couldn't help us. Any suggestions?
Jan 29, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Dec 27, 2007 | Ovens
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Kitchen Ranges Logo
1,462 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
