Wireless Acquire network address problem
I purchased this Belkin Model F5D7633AU4A wireless router and had it setup...I show an Excellent signal...but it will not acquire a wireless network address.....it works well with the cable attached....but not as a wireless....I had a D-LINK 604T before which the wireless network encounted no problems
    Sergeant:
  • 284 Answers
Belkin has a wizard to help you with the wireless setup.
maybe you have a security option turned on. check the router for security options.
make sure its on disable security to check the wireless part also check to see if the wireless option is turned on.
Posted on Jun 25, 2008
Belkin N1 Wireless ADSL2 Model # F5D8631-4 Router router default address (192.168.2.1) is not opening, even i have reset the router
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 09, 2012 | Belkin Computers & Internet
I have a Belkin wireless router model F5D7633AU4A and I show a Excellent signal.....but it will not Acquire a network address
Do you mean your computer wil not acquire a network address from the router? If this is the case on your computer, click on start then click on run, in the run window type in cmd and press the enter key. You will now be in the windows doss prompt. Once in the doss prompt type in 'ipconfig /release' with quotes removed and press enter. After you do this type in 'ipconfig /renew' with quotes removed and press enter. After you do this restart the computer and see if it acquires the address. If this does not work try restarting the router. Keep me posted. If you found this solution helpful please rate it. Thanks - Tech101
Jun 25, 2008 | Belkin Computers & Internet
Can i setup the belkin f7d4302 as a wireless bridge
belkin does not support this. The only way you can do it is by running a cable to the router to extend your wireless signal around the house. I did a similar setup with a powerline network adapter if running a cat5 cable is not a option. just make sure you change the main ip address for the 2nd router to like 192.168.2.2 and disable dhcp since the main router will handle dhcp. also make sure the wireless settings are the same and channel is different if 1st router is channel 1 then use channel 6 or 11 for the 2nd router.
Feb 26, 2012 | Belkin Wireless Play Router (F7D4302)
I have a Belkin wireless router connected to a Virgin modem. Always has worked fine with a Compaq laptop and 2 Dell Inspiron netbooks with excellent signal. Now have tried to connect with an Acer Revo rl...
The router is designed in such a that it is compatible with all the computers. The best way to get rid of this issue is log into the router interface and change the wireless channel to suit your requirement.
1) To begin with.. Open internet explorer on a computer connected to the router and delete everything from the address bar and type http://192.168.2.1 and hit enter. Now you will be in the Belkin Router setup. It will ask for a login password when you click on anything.. Leave the password field blank and click on submit. 2) Towards the left side under wireless click on "Channel and SSID". Now you see wireless channel change it to different channel and click on "OK / Save". Now check the signal strength in your Acer computer. If its still the same try different channel and check.
Hope this helped.
Feb 22, 2011 | Computers & Internet
Wireless connection to belkin g router model no. f5d7230-4
You need to access the setup page of the router using connected computer.
In your browser's address bar, type 192.168.2.1.
By default, leave the password blank.
On the Belkin setup page, go to Wireless.
Take note of the SSID. This is the name of your wireless connection.
Then go to Security under Wireless. Copy the network key.
On your friend's laptop, view the available wireless networks, you should see the SSID, then just enter the network key.
I hope this helps!
May 18, 2010 | Belkin (F5D7230-4) Router (587009)
Connect my Lynksys WRT54G2 Router with my Belkin (F5D6231-4)
You can connect 2 routers to each other. But the IP address will be different for both the routers .
It will be better to keep different names for the wireless network.
If you keep the same name, then it doesn't mean that the signal strength will be good. Because both the routers will broadcast their own signals.
If you want to increase the signal strength then you can purchase a wireless range expander.
Click Here for more info about the networking
Nov 04, 2009 | D-Link Wireless Starter Combination Kit...
Wireless
Have you configured the Belkin wireless router?
You need to configure the Belkin using a 10baseT network cable first before you configure the wireless card.
To make your wireless router secure you need to use your browser and type in the Belkin IP configuration address.
Then you need to change the Admin password, change SSID and turn off SSID broadcast, setup the encryption (use WAP or WAP2 if your wireless card supports WAP) and for added protection use MAC address filtering.
Apr 12, 2009 | Acer Computers & Internet
I have netgear sky router belkin wireless g usb adapter sinal strength is excellent but it wont connect keeps saying acquiring network adress what can i do it has worked in the past and oblige
go to the router setting by logging in as a administrator then check the wireless setup access, then add your WIRELESS DEVICE 12 digital MAC address then apply it and logout
Sep 29, 2008 | Belkin Computers & Internet
Wirless network problem
the belkin router gets the wire from the dsl/modem in the seperate jack port in the back then punch into the address bar on a explorer window
192.168.1.2 and make sure you have it set to unsecure network, you can fiddle with the password system later on securing the network.
Aug 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
