I am running Vista and when Panning in AutoCAD 2008, the window goes diagonal as when 'switching between windows'. How do i disbal this Vista feature when I'm using AutoCAD? Any assistance would be appreciated. Allen
  • raro9 Jun 30, 2008
    thank you for your help.
    Sergeant:
  • 284 Answers
Check the option in the video card drivers i dont think vista has
that option, usually Nvidia or ATI has a control panel for fixing the
way LCD's behaviors
Posted on Jun 25, 2008
  • Arcadian Duran
    Arcadian Duran Jun 30, 2008
    Good luck And Thanks!
AutoCAD Windows 7 64bit
AutoCAD 2008 is not supported to run on Windows 7 (2010 is the first release that is). Try running the OS in XP / Compatibility Mode for increased performance.
Philip
AutodeskCare' Community Manager
TW ' PI ' YT ' BLOG
Aug 17, 2012 | Autodesk AutoCAD 2008
AutoCAD 2004 / Windows 7 compatibility?
If it works in Vista you shouldn't have any problems. Easiest way to find out is to install it!
You can always just uninstall the program fi you run into problems.
Dec 05, 2009 | Autodesk AutoCAD 2004 for PC
Help! I have vista preinstalled in my laptop, can't run autocad
This is the price to pay for pirated stuff!, I suggest you uninstall your software and re-install it but before doing so make sure that your internet is disabled (manually disconnect from you provider or disable your wifi card). Then do your work, saves your files and connect to internet without running your software if you need to send a draft to a friend.
Hope it helped,
Lucus123
Apr 02, 2009 | Computers & Internet
AutoCad R14 to Vista - bab-Mem-Pointer error message
You are still using AutoCAD R14? If you are that might be the problem. If you are running Vista, then AutoCAD R14 might be too old of a version to run. You will probably need to upgrade to a newer version of AutoCAD. I know this isn't a solution, but I am just trying to look at it from a different point of view. You can also go to autodesk.com and join their discussion groups. It is free and you can post questions. You usually get a fast response with an answer that really helps. I will do a little more research and add more when I get a chance. Good luck and I hope that I helped.
Feb 22, 2009 | Autodesk AutoCAD LT 2008 - Upgrade for 5...
32 bit program to 64 bit opperating system
From the Autocad webiste:
System Requirements AutoCAD® Civil and AutoCAD® Civil 3D® 2009 Recommended System Requirements Recommended configuration (excluding server components used with project management capabilities):
  • Intel® Pentium® 4 (3 GHz or higher); AMD Athlon™; multiple processors supported, dual-core supported
  • 32-bit only: Microsoft® Windows Vista® Ultimate/Business/Enterprise, Microsoft® Windows XP (SP2)
Note: Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
Here's how you should be able to run it in compatibility mode:
1. Right click on the Autocad Icon in your start menu
2. click on Properties
3. click on the Compatibility tab at the top
4. check the box next to Compatibility Mode and select Vista 32 bit if it is given as an option.
I don't have Vista here, but that is how it works in XP and I did do a search and it appears to be the same in Vista.
Feb 07, 2009 | Microsoft Windows Vista Home Premium with...
I have a Windows Vista 32bit machine ive installed autocad2008 but i plotter wont plot
IS the driver for the plotter installed? Can you plot using any other program? Is there a test feature in the plotter driver so you can test the plotter? What plotter is it?
Nov 14, 2008 | Computers & Internet
I have been running autocad 2008 on my old pc under windows xp cannot get it to start under vista ?
Maybe you need an updates to run in windows vista..please see documentation operating system requirements.
melnavz
Oct 25, 2008 | Computers & Internet
AutoCad LT 2006 incompatible with Windows Vista
some of the older versions of autocad does'nt tend to work in vista.try installing autocad 2008 or 2009.it is recently released and well compatible with vista.REMEMBER, if u r using it for architectural purposes,try downloading autocad architecture 2008.it is especially made for architects.try downloading it on torrentz.com
Jun 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
PLEASE HELP
some of the older versions of autoca does'nt tend to work in vista.try installing autocad 2008 or 2009.it is recently released and well compatible with vista.REMEMBER, if u r using it for architectural purposes,try downloading autocad architecture 2008.it is especially made for architects.
Jun 06, 2008 | Autodesk AutoCAD 2006
Windows Vista and Autocad r14
try this thread from autodesk it is having solution
Feb 02, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
David Payne
David Payne
