R60 Wont Charge
What's the make and model of your laptop? Most times the flashing lights will tell what the issue is.
If the laptop will not boot up so you can use it then the things below applies.
Sounds like your power cord is bad. Or the DC Jack is not soldered on
good. Just because the power cord is new does not mean it works. Some
Power Cords have a little green light on the adapter to show that it is
plugged into the wall and getting power, check yours.
Anything ever post to the screen when you hit the power button? Do the
fans start up, the hard drive spins? If not, maybe your power cord has
enough power to emit a light but not enough to start the fan or disk
drive.
If it's not the power cord or dc jack, then you have a Memory or Video Card issue.
OK after reading your post a 2nd time I think your only issue is that
the battery is not charging, correct? If that is true the things below
applies:
Either the battery is bad or the power cord is bad. Just because they
are new don't mean they work. See if the Adapter portion of the power
cord has a green indicator light that comes on when you plug it to an
outlet. If it does, and that light is not on the power cord has
issues. Also I hope you did not buy one of those one size fits all
power cords from the big box stores where the end has a bag of different
interchangable parts until you find one that fits into the laptop. If
so, buy a power cord off ebay that is made for your laptop.
The battery might be bad and not hold a charge. I have seen new batteries that did not work.
This happened last night we left it unplugged all night and I tried it again this morning to no avail. Its pretty new only about 2 weeks old so I am just going to return it I think. There must be something wrong with the actual unit itself.
I have same model. HWR08CX7. I bought it yesterday. After installing into the window , and plugging in, it performed the self-check. Then it started up, ran for about 5-8 seconds and shut off. It would not start at all after that. The green light is lit on the plug. I have tried tripping and resetting the plug, let it sit overnight, but to no avail. I called Haier customer service and they told me to return it to the store. I exchanged it today. I took the new one home and plugged it in. It worked fine. Then I put it in the window and it will not start. I called customer service again. The only thing I could think of was that the electrical cord was compressed out of the unit. The unit sits on the cord in the window. I have taken it out of the window, unpluggged it,waited the 3-5minutes customer service said to then tried again - out of the window. It will not start. Surely there is something that will work. This is 2 units (same model) in 2 days.
I HAVE THE SAME PROBLEM.IT WILL NOT START AND SHOWS ON THE DISPLAY E1. I HAVE TRIED EVERYTHING SUGGESTED.
Unit went off and will not come back on. Has an E1 code on it. Have had it about 2 months. Of course it's late at night and the temperature outside is about 100. I am so disappointed in this unit.
have same found wires on power cord is pinchened where they secure it to chassis causing short i fixed wires now fan runs but when compressor tries to start circuit board chatters and compressor wont start i think its either shorted circuit board or capacitor,tring to find where to buy parts does anyone know where to go for parts can't take it back lost sales slip
ive plugged, unplugged, done it all over again..just wont start
