Monitor Out I'm trying to connect my audio receiver to the audio out or monitor out connectors but I'm not getting any sound.
  • danbrockway Jun 26, 2008
    Actually, I'm hoping to route the audio signal from my DVD player directly to the TV so I don't have to use the sound from the receiver. But also route the audio from the TV to the receiver so I can optionally use the amplified sound from the receiver. That's why I am trying to get the audio out of the TV.
  • 10,594 Answers
No no, you should connect receiver wires into Input terminals of TV.
Posted on Jun 25, 2008
  • Shahid Electronics
    Shahid Electronics Jun 26, 2008
    OK, now I understand the situation. After connections of cable, you should select Video/ Aux in your receiver to listen sound of TV.
I have a MAG Innovision Model 468 LCD Monitor and a Compaq computer, how can I get the monitor speakers to work?
There should be a wire to connect between the speaker output of your soundcard (usually the green connector) to the monitor's speaker input. It should be a "mini" plug, 3.5mm diameter. Make sure your speakers are not muted in the audio/sound controls on the computer.
Aug 24, 2011 | Computers & Internet
I dont have any sound
Hello, without asking you loads of Q's about how you're connecting it to to your computer etc, don't forget you have to connect a cable from your computer's audio card output to your monitor's audio input connector in order to get the sound to come out of the monitor's speakers. Hope this helps! Regards
Nicam49
Aug 03, 2011 | Westinghouse Electric SK32H640G 32"...
Cant get sound from inbuilt speakers benq E 2420 hd monitor
Check your connector of audio input of the monitor to an output of the source of the sound that you want to hear in your monitor. For example the audio output your computer to audio input of your monitor. Check if there is a loose connection or loose wire.
Jul 25, 2011 | Computers & Internet
Received a new monitor for Christmas, but I'm not sure if it has speakers. My old monitor did, so of course, when I removed it, I removed the speakers as well. I do have an old set but I'm not sure how...
If the new monitor does not have an audio input or an audio lead from the monitor then it does not have built-in speakers.
You can attach speakers to your computer, connect the speaker lead to the audio out connector on your computer, this connector is usually colored a green.
Dec 29, 2010 | AOC 416V 24 inch Monitor
Connect a monitor to a yahama HTR 5660 receiver
"trying to connect multiple devices to a yamaha receiver if I am using an S video to connect the tv (monitor) to the receiver do I plug it into the monitor OUT s video or would it be Input not output?" Input on the Monitor from Video Out on the Yamaha.
"if I am only using the monitor for video and not sound do I still need to plug in the audio cords or do i leave them out " - Presumably the monitor doesn't have speakers or audio connections, so it's a non-issue. Your video sources should have audio routed to the receiver. If the monitor has speakers I would also send 2-channel analog audio to it from, say, the cable/satellite box, so you could hear the weather or other lo-fi video without turning on the Yamaha.
Mar 30, 2010 | Yamaha HTR-5660 Receiver
No sound coming to the speakers.
What is the model number of your receiver?
Many receivers don't support audio over HDMI, they just switch the signal from hdmi-in 1-4 to hdmi-out, but can't analyze the data to take audio out of it. Your receiver is probably one of those.
You need to connect the DVD player also via spdif digital cable. Look at the player to see if it has optical (square black plug) or coax (orange RCA plug) connector. Receiver probably has both of them.
Feb 27, 2010 | Audio Players & Recorders
I have a ps3 and a samsung flatscreen im using an hdmi cable is there anyway to run the sound through my kenwood vr 305 since it doesnt have a hdmi input
Connect cables from your flatscreen TV (or monitor?) to the receiver's audio input jacks. These could be two RCA, white and red, or Digital (one single RCA cable), or optical, if both the flatscreen and the receiver have such connector. Make sure you select the correct audio input on the receiver to amplfy the sound from the game/movie/etc.
If successful, try muting the TV's audio, to prevent the sound from creating a hollow (echo) effect.
Dec 02, 2009 | Kenwood VR-305
I have a syncmater 2333 HD and after connecting to my pc, i seemed to have lost all sound. when connecting speakers and earphones, there is still no sound. thanks
Did you plug in the audio cable to the back of the computer? If so, this may have disabled the front audio connections (or vise-versa). Try unplugging the audio cable from the computer (that is connected to the monitor) and see if your headphones work. If so, there is the solution to that problem.
Check the audio connection on the back of the monitor and double check that it is plugged into the correct port on the back of the computer. If the monitor has amplified speakers, it would be a good idea to connect to the 'line-out' connector on your computer. This would avoid disabling your front audio panel.
Lastly, check the volume on your monitor's built in speakers. This monitor can double as an LCD television, so it most likely has a separate volume control (that defaults to 0).
Oct 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Televison & Video Logo
Top Televison & Video Experts
