Question about HP Photosmart 2610 All-In-One InkJet Printer
Error Message Error 0x886a6b72
My HP Photosmart 2610 All in one is messed up.
The screen shows the error message above then A lot of ???? and stuf at the bottom. All lights are flashing and the computer says it does not recognize the USB device. This printer and computer have worked together for a couple of years. Had a storm the other day and the Ethernet was knocked out. Maybe my printer too ?
Can anyone help?
  • 2 more comments
  • xiangkong97 Jul 03, 2008
    I have the same problem to my hp5510xi all in one fax scan printer machine,if you know how to fix,please sent to //
    Thank you
  • Anonymous Jul 08, 2008
    it looks like a pict-bridge port problem. When I plugged in my usb mp3 player to it to charge it looks like the photsmart did not like it, since it got this error message.
  • Anonymous Aug 12, 2008
    This printer/scanner has worked fine until a recent storm. Now none of the work stations on my home network can access the printer/scanner.
  • rossd69 Feb 22, 2009
    There was a lightning storm here aswell and we have the same problem with the HP 2610. It says Error:0x886a6b72 and all the lights are flashing green.
I contacted and after a while we decided it is fried.
Lightening had hit my cable box and must have got the printer too.
All it will do is flash even after trying to reset to factory settings.
Thanks for the offer
Posted on Jun 26, 2008
What to look for when it keeps saying ... Error .... Remove and check color Cartridge?
I suggest you run the 'Tap 10' diagnostic test pattern for your HP PS 2600 series printer model...this will display the electrical health of the ink cartridges and confirm that your printer is operational (I am guessing one of the ink cartridge control lines is open).
Good luck
Mar 06, 2013 | HP Photosmart 2610 All-In-One InkJet...
My HP Photosmart 2610 won't recognise compatible cartridges, help
You can try buffing the contacts gently but this happens quite often with generic cartriges sometimes they just don't work. Contact the vendor and explain the issue, I reckon you'll find that they're fairly used to this problem and will request a return for a refund.
May 31, 2010 | HP Photosmart 2610 All-In-One InkJet...
Photosmart 2610 with power on get Error 0x886a6916
0x error codes indicate that the product has an internal error. Try to reset the printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Printer keeps blinking error 0x886a6b72
have a look on here HP Photosmart 2610 All-in-One Printer
if you need the drivers they can be found on here as well
hope this helps
Dec 14, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 showing error report 0x886a6b72 How do I fix this problem
no way to fix it, the very small chip they used to process the data stream is extremely sensitive to changes in voltage, and will cause that error almost constantly. sorry to say it, had one myself, took it apart and tested to find out why. ended up getting a brother mfc-210c and never had a problem since
Nov 04, 2008 | HP Office Equipment & Supplies
Problem with HP Photosmart 2610
You need to reset the printer.. Unplug it from the power.
Then please remove the USB Cable from your PC completely.
Restart your PC without connecting USB cable back to your PC.
Now connect the USB Cable into the USB Jack from both ends and start your PC.
After doing above steps please reboot your PC finally.
And push the power button for 4 times and then power on .
Let me know the result, so I can further investigate the problem.
Oct 14, 2008 | HP Photosmart 2610 All-In-One InkJet...
Printer HP Photosmart 2610 all-in-one
I found this link, which i think may help you out.
Copy&paste it in a browser!
May 30, 2008 | HP Photosmart 2610 All-In-One InkJet...
Error Message: Remove and check cartridge on right.
Just perform a full reset of your printer and it will be done for..
Mar 21, 2008 | HP Photosmart 2610 All-In-One InkJet...
Error Message
I changed the black ink cartridge in my printer with an appropriate hp product. I am not able to insert the cartridge correctly in the system. It constantly reads, remove and receck cartridge on right. I have purchased two ink cartridges at this time. Do you think the printer is broken? Please respond.
Mar 06, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
874 people viewed this question
Ben Johnson
