Digital converter box setup
I followed the directions to hookup the Insignia NS-DXA1 box to my RCA F27650. I have an outside antenna. I used the A/V cables. I set the TV to input 1. The box has a blue light and the TV says "Unusable Signal". Am I doing something wrong?
    Scholar:
  • 78 Answers
Hi Kilroy75,
It sounds like you probably set this up properly. The converter box is powered on, indicated by the blue light (it is illuminated red if powered off). I would recommend that you check to see if your TV has to be on a specific channel to receive external input.
To double check the connection, you should be able to follow the antenna into the converter box, then the converter box into the TV. Check to make sure you have input/output correct, and that video matches video, audio matches audio, etc.
Also, some antennas require power. If this is the case, make sure the antenna is plugged in and powered on.
If none of these suggestions help, I would try a little troubleshooting to determine which piece of equipment is giving the problem. Try connecting another device into the same input to see if your TV receives signal through input 1. You may also try a different set of A/V cables or a different input on the TV.
If you still are unable to get your setup working, I recommend you bring the converter box into your local Geek Squad® precinct for further troubleshooting and advice.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 25, 2008
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
May 16, 2011 | Insignia Televison & Video
Have an Insignia (NS-DXA1-APT). Have tried 3
connect up another tv and see if it is the tv or where you live.if the tv is the culprit then you have a defective tuner in the tv and is probably is not available.
Jul 18, 2009 | Televison & Video
RCR Universal Remote Code for Insigna HD Converter Box NS-DXA1
Try 189 or 244 or 309..........Hope that was helpful Thanks for using Fixya.com.............enjoy your evening!
May 30, 2009 | RCA 3-Device Universal Remote
Programming Insignia Digital Box to Phillips Universal Remote
I have the Phillips Universal Remote (model#SRU4208WM) and I have the Insignia digital converter box (model#NS-DXA1-APT). The code was 0267. The Insignia converter box is the one the government grants work for.
Feb 03, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital converter box NS-DXA1 saying no signal
Connect your Insigna unit to your television video 1 input. Connect your antenna to the Insigna. Turn on the television to video 1 source. Power on the Insignia. Now go through the auto-detect routine to set up your television stations.
Dec 29, 2008 | Insignia Digital-to-Analog Converter for...
Lost the Welcome/Installation Menu
http://www.ezdigitaltv.com/support-files/ns_dxa1_manual.pdf
All you have to do is use the auto tuning function. Your remote control has a menu button, you can get to the feature via the on-screen menu.
If you press the menu button while the box is on and you see no menu, change your television's input to match what the box's output is.
Nov 23, 2008 | Insignia Digital-to-Analog Converter for...
Insignia NS-DXA1 - Digital to Analog converter box
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
May 19, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
Electro Med Services...
