Question about Belkin Computers & Internet
I have a Belkin wireless router model F5D7633AU4A and I show a Excellent signal.....but it will not Acquire a network address
  • 868 Answers
Web.belkin.com/support/d...load=1662⟨=1
copy & paste the link above if you haven't already. It has solved the problem your having with network address issues. Keep me posted if you need anything else.
Posted on Jun 25, 2008
    Novelist:
  • 121 Answers
Do you mean your computer wil not acquire a network address from the router? If this is the case on your computer, click on start then click on run, in the run window type in cmd and press the enter key. You will now be in the windows doss prompt. Once in the doss prompt type in 'ipconfig /release' with quotes removed and press enter. After you do this type in 'ipconfig /renew' with quotes removed and press enter. After you do this restart the computer and see if it acquires the address. If this does not work try restarting the router. Keep me posted. If you found this solution helpful please rate it. Thanks - Tech101
2 Suggested Answers
MrARCADIAN
  • 284 Answers
SOURCE: Wireless Acquire network address problem
belkin has a wizard to help you with the wireless setup.
maybe you have a security option turned on. check the router for security options.
make sure its on disable security to check the wireless part also check to see if the wireless option is turned on.
My drivers 3 years old and cant find a new one
go to the Belkin's official website and search for the latest firmware for you model and upgrade it.
Regards:
Himanshu
Aug 27, 2012 | Belkin F5D7633AU4A Wireless Router
Having an issue getting my laptop connected to the internet. The wireless networks appear and it shows that i am connected to the linksys, however i get a dns server issue when i try to go online. It shows...
I see that your having issues with you wireless connection, you mentioned that it is an old model Router that has a B wireless signal and that you are connected to the Router but you get an Error about the DNS having issues, try checking your Routers Network Key, make sure that your Network Key in the Laptop and Router are the same.
- to get in your Belkin Router you must type in your Default Gateway on you browser ex. IE, Firefox 192.168.2.1 then press enter after typing your Belkin's Default Gateway you should get a window prompting you for a user name and password
your user name would be admin and the password leave it blank then press enter unless you have changed the user name and password setting of your Belkin.
- check under wireless and security to see your Network Key/Security Key and copy what you have in you router and use it on your laptops network security to be able to access internet from your Belkin Router.
Hope this helps.
Apr 02, 2011 | Linksys Computers & Internet
I have a Belkin wireless router connected to a Virgin modem. Always has worked fine with a Compaq laptop and 2 Dell Inspiron netbooks with excellent signal. Now have tried to connect with an Acer Revo rl...
The router is designed in such a that it is compatible with all the computers. The best way to get rid of this issue is log into the router interface and change the wireless channel to suit your requirement.
1) To begin with.. Open internet explorer on a computer connected to the router and delete everything from the address bar and type http://192.168.2.1 and hit enter. Now you will be in the Belkin Router setup. It will ask for a login password when you click on anything.. Leave the password field blank and click on submit. 2) Towards the left side under wireless click on "Channel and SSID". Now you see wireless channel change it to different channel and click on "OK / Save". Now check the signal strength in your Acer computer. If its still the same try different channel and check.
Hope this helped.
Feb 22, 2011 | Computers & Internet
Connect my Lynksys WRT54G2 Router with my Belkin (F5D6231-4)
You can connect 2 routers to each other. But the IP address will be different for both the routers .
It will be better to keep different names for the wireless network.
If you keep the same name, then it doesn't mean that the signal strength will be good. Because both the routers will broadcast their own signals.
If you want to increase the signal strength then you can purchase a wireless range expander.
Click Here for more info about the networking
Nov 04, 2009 | D-Link Wireless Starter Combination Kit...
Wirless network problem
the belkin router gets the wire from the dsl/modem in the seperate jack port in the back then punch into the address bar on a explorer window
192.168.1.2 and make sure you have it set to unsecure network, you can fiddle with the password system later on securing the network.
Aug 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have tried to install router strait from modem to router to toshiba l30 laptop belkin shows up on laptop showing excellent signal but when i try to go on web it cannot make contact
access your routers administration by right clicking your network icon and using your gateway IP to access http://*gateway*
un - admin pw - (none), admin, public
look at your status in the belkin administration settings and see if you have an ip and gateway for your ISP.  The ip and gatway on your computer is for your belkin.
Try directly connecting the laptop to the router with a cable and see if it's on the net. If it is then you have wireless settings wrong. See belkin.com for more infor about router.
James Mac
Aug 02, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Jun 25, 2008 | Computers & Internet
Acquiring network address
if you are using the dell wireless utility to manage your card, then disable it, and manage your wireless adapter through the windows network connections. that way the wpa issue will be solved by windows xp wpa. i had a similar problem with my inspiron 1525 (dell wireless 1395)
Jun 09, 2008 | Computers & Internet
Wireless Internet Connection
Are the wireless router connected to a network?
Oct 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
98 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
