Question about Panasonic PT-47WX49 47" Rear Projection Television
Model 6p6030 w101
Is the screen replaceable and how expensive would it be. i got this tv for free and i am not sure if the screen it came with is the correct screen.. it appears to be some sort plexiglass material.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 31 Answers
Some projection sets have a screen Protector ( plexiglass) along with two other sceens that can cost alot!...
Posted on Jun 30, 2008
Crosley projection tv
Sounds like one is not recognizing the other, By you not being to get into the set up menu means it is not seeing your blue ray player. Are you sure they are compatible? If so then if there is another way to hook it up, like with RCA cables then try that. Also make sure that there is not more than one S-video option on it.
Mar 12, 2014 | Televison & Video
Philips magnavox 6P6030 W101 picture is too big and can't see the outer edge of the full picture
Not easy with a older set----look to see if a physical control exists in the set for Vertical size (picture too tall) and the adjustment may only exist in a hidden on screen menu.
Jun 11, 2012 | Televison & Video
Hello. there is some green lines appearing on my 42 inch norcent plasma monitor display. what could it be? usually it starts after one hour of the tv being on. and if I leave it on for more thatn an hours...
Dear Sir,
Welcome to Fixya.
The problem is related to plasma it is very difficult to fix the problem,so solution is you have to replace your tv plasma screen.But it is too much expensive.Depending on your Plasma EDTV model and size estimation can be done.If it is in warranty you can get free replacement.Visit nearest Norcent Service Centre for more detail.If you have any problem regarding this issue leave a comment we were happy to assist you.
Have a Nice Day.
Oct 08, 2009 | Norcent Technologies PM-4203 42 in....
Projection TV Screen is scratched/Speakers Don't work
u can buy new screen toshbia.com tv parts sears.com tv parts cost i have replace 1 before screen 300 bucks be very careful glass extremly thin thin will crack good luck
Aug 06, 2009 | Toshiba Televison & Video
TV Contrast Problem for Philips Magnavox 7P4830 W101
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 18, 2009 | Philips Magnavox 51MP392H Rear Projection...
Changing the coolant fluid on a magnavox 6p6030
There is no free service manual for your model as its a large service manual that covers many models. You can however get the Phillips coolant replacment instructional CD, or the entire coolant kit with the coolant and instructional CD at the following link. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Aug 03, 2008 | Televison & Video
Philips Magnavox Model 7P6033 W101 (60") moved tv and picture now has distorted vertical hold
ok..... I,m a dummy !!! but not DUMB .....enough to play this freaking game When I figure this **** out I will POST it
Jul 23, 2008 | Televison & Video
Magnavox RR1337 W101 skipping stations
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Aug 26, 2017 | CTX Televison & Video
3 Digit Product Code for Magnavox tv RR1337 W101 (13S401-00AA)
0807 works with a Philips Universal Remote on my Magnavox RR1337 101
Apr 28, 2008 | Televison & Video
Magnavox model# 6p6030-w101
change the coolant in the green and blue CRTs. Then also poloish the mirror by cahnging the coolant your set will be as bright as when it was new. If you need more info, please let me know.
Apr 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
