Question about Maytag Washing Machines
A Maytag repair person put a new motor in our Neptune washer and it is doing well except on the last spin cycle the machine will stop and a code "LO" will display. I do not have a manual and would like to know what this code is trying to tell me. Thanks, Ms. Gray
  • 96 Answers
Which Maytag model is it?
Posted on Jun 25, 2008
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Maytag neptune mah5500b sr code
Machine control is attempting to drive the motor but is not seeing any tach response.
Visual check shows motor is not moving. (Locked, Hall Sensor fault).
Evaluate wire harness for loose or unhooked connections.
Oct 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag toploader Neptune washer stops with 10 minutes left on quick wash and code "uc" on LED. There is a little water left in bottom of tub and cloths are soaked. It does fine until the spin...
It sounds like the Outer Bearings are going due to a leaky Tub Seal. Bothe can be repaired and have done on this site. This site has no way to reference past post to machine issues.
I have helped owners of theFAV6800A and FAV9800A machines here but I prefer a tru DIY site.
I no longer post on this site no way to post a Sticky for machine issues.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" Read the post Part 1; DC or UC unbalance error codes in Spin Cycle what is causing this issue? Part 2 for the fix action.
Post your issue in the repair forum not in the Sticky. Please include your Model Number i.e. FAV6800A or FAV9800A and I will help you.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer model mah6500a, took the back off and the tub spins but still get the code Lr
Looks like another motor/motor control panel replacement. This machine has a faulty motor/motor control board, it has been re-engineered with a replacement. Has yours been replaced? Have you found the tech sheet behind touch panel and placed machine in service mode to test? We had the same issue, worked sporadically, didn't drain, got LR code then eventually stopped working. Check your spin in service mode, if it doesn't spin properly you should find out here. It is a very simple repair in all actuality. Contact Maytag and they will sell you the parts for a discounted price, make sure that you buy directly from Maytag, also check your boot very carefully since that part will also fail and allow water to get into the bottom of the machine where you have electronics.
Feb 15, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah8700. Will spin at the end of quick rinse cycle but not on any other cycle. Error code I get is SUSP. Washer does drain out.
Hi
My name is Gloria, my neptune washer will not spin on the last spin cycle of any of the washing cycle. A code of uC comes up.
Aug 08, 2008 | Maytag Washing Machines
only 2 or 3 real problems with this machine, bad machine controller( behind console) although lights on are sign that its good,
Either the pump is clogged and not draining water so it will never spin let alone spin full speed with water in tub, i also doubt that because it seems that s there just water within the clothes and not a tank full of water,
which leaves the last Major issue with machine and that's the motor controller, not telling the motor to spin.. could also be a bad motor but i really doubt that all....
This is a funny machine because depending on when it was made (serail number denotes its age) im looking up the model and your manual states that you have a 3rd yr to 10 yr part warr on the motor, Well on earlier models you cant replace the motor itself it comes as part of a kit, "NEPTUNE REPAIR KIT" which also includes the motor control board. reason i mention that is I"m able to get a motor controller covered by warr(as an authorized maytag technician) if the model will take the neptune repair kit, sure youll need to pay service and labor but the a part would be covered.
Mar 20, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
