Question about Maytag Washing Machines
Washer will not agitate, but will spin - Maytag Washing Machines
  • 96 Answers
If this is a top-loader then sounds like the clutch.
Posted on Jun 25, 2008
All the program working normal except agitator cycle
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Apr 06, 2015 | Hoover Washing Machines
Our whirlpool wtw5100vqo agitator doesn't work I already replaced the agitator dogs
Apr 03, 2015 | Whirlpool Washing Machines
Replaced lid switch, water level sensor and timer. Machine fills and does nothing - no agitate / spin
Apr 03, 2015 | Washing Machines
My machine will fill and drain, why won't it t agitate or spin
Mar 28, 2015 | Washing Machines
My roper washing machine will fill with water, but will not agitate, rinse or spin, but will drain. It makes a horrible noise during all cycles except when filling with water. What is or could be the...
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 17, 2015 | Roper Washing Machines
What would cause my maytag front load washer not to spin? It is a Maytag front load washer and it will not spin. The water drains out no problem just doesn't spin. Also the drum looks lower than it no
Jan 06, 2015 | Maytag Washing Machines
Washer won't agitate or spin
Oct 12, 2014 | Whirlpool Washing Machines
Whirlpool washer fills sometimes and won't agitate or spin or drain what should i do
Jul 24, 2014 | Whirlpool Washing Machines
Dryer not spinning when loaded
Jul 02, 2014 | Whirlpool 3.2 cu. ft. Washer
Washer does not spin
Mar 23, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Washing Machines Logo
143 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
