I have the B100 and opened it up and basically did your fix without knowing it. But now my Keurig has a flow that seems too strong. I dont know if this had anything to do with it but I pushed the little button in between the two black wires in the section just towards the left of the check valve/pump area. Any Ideas? Water seems to gush out of the top and bottom of the k-kup.
It sounds like one of two things happened when you disassembled the unit. Either the hose that controls the mechanism for the piercing arm (the part that puts the holes in the k-cup) became disconnected or pinched, causing the water to pour out over/around the k-cup. Or the k-cup holder is clogged or not seated correctly, which would cause the same problem. As for the little button you may have pushed, that can't cause the problem you're experiencing, so don't worry about that. Good luck, let me know if need more help. Erik
Hi.. I have the single serve model and the start button wouldn't engage the machine this am... what...
(More)
Hi.. I have the single serve model and the start button wouldn't engage the machine this am... what should I do?
