Question about HP PSC 2210xi All-In-One InkJet Printer
Fax problem I just had my two phone lines one for fax one for phone changed to one. The phone works fine, but when the fax number is called the fax machine is suppose to pick up...AT&T said you have to make sure the fax is set to pick on on 2 rings..I don't know how to do that?
    Scholar:
  • 137 Answers
You will need to enable the "Distinctive Ring" feature on the PSC 2210 as shown here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Jun 25, 2008
  • Bob Headrick Jun 26, 2008
    A "Thanks for trying" rating would indicate that your problem is not solved. What problem are you still havng? The link has the method for setting up your 2210 to answer only the double-ring, which sounded like what you needed. Did this not work?
    - Bob Headrick, Microsoft MVP Printing/Imaging
None of our faxes are going out and we receive error number 87
set the fax so you can hear dial tone... if no dial tone then check the fax line.... if fax line plugged in... plug it out of the fax and plug into a phone... if still no dial tone then change fax cable... if dial tone... then call your cell... if static... fax wont work call phone company... if you get a funny signal call phone company...
Dec 10, 2009 | Office Equipment & Supplies
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
CANNOT RECEIVE FAXES ALL OF A SUDDEN
Check the phone line with a basic old phone plug it into the fax line do you get a good dial tone, and no noise on line. Also check the phone line call ATT and have them check the number move the fax machine to different plug. power off the wait tens second power on. check the phone line connector.
Mar 31, 2009 | Minolta Office Equipment & Supplies
Fax mach wont receive from other faxes
I'm sorry....Do I have this right? You say that another fax machine was hooked up on the same phone line and you have the same problem with that one. So the problem is related to that phone jack?
It sounds to me like there must be just the slightest amount of interference in the jack, interfering with the fax. They are far more sensitive than just a telephone. You could try a phone line filter.
Feb 27, 2009 | Brother MFC-8220 Fax
Switched to shaw digital phone service from mts. my ph # and my fax # are different numbers but when phone calls come in the fax picks it up instead of the phone.how do i change this?
Call a cell phone from the fax machine to find out what the machine's number is.
Be warned, tho, fax machines will not work reliably on digital phone lines.
Feb 20, 2009 | Brother IntelliFAX 2800 Laser Fax
Fax one phone/fax line but always answered by fax
You can change the number of rings before the fax machine can pick up. Three is usually a good number. You would have to pickup the phone on the first two rings.
They make devices that do that but everytime I have used them I would end up getting the fax tone when I'm trying to make a voice. The boxes are great at dealing with incomming phone calls from pstn or land line based calls, but if you are getting cell phone calls or voice calls comming in from digital, DSL, or VOIP lines, it has a hard time sensing voice from fax when people are using phones like that. There designed for analog phone line installation but if you're on a DSL they won't work.
Sep 15, 2008 | Samsung CLX 3160fn All-In-One Printer
Fax network not working
Is your phone line plugged into the proper receptical on the fax? It should be plugged into the LINE slot, not the PHONE slot. The PHONE SLOT IS TO CONNECT A TELEPHONE TO THE FAX. IT IS NOT FOR THE INCOMING PHONE LINE. If your phone connection is correct, try calling your fax machine from a cell phone while you are at the fax machine. Listen on the cell to see if the fax machine picks up the line. If it does not, go into your fax machine's settings, either INITIAL SETUP FAX SETUP, or PHONE SETTINGS. You may have to try several settings to find one that works, depending on your fax machine. Try going to RECEIVE SETUP on your fax machines setup menu. Scroll through the settings, writing each down on paper. Try RING DELAY, RING TIME, NUMBER OF RINGS TO ANSWER , or any other settings relating to how your fax answers the phone line. Try changing each setting, one at a time, and try calling your fax to see if it answers. There may also be settings on your fax to set it up if an answering machine or telephone is on the same line.
Jul 17, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Feb 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
Jun 14, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
HP PSC 2210xi All-In-One InkJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
