Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Overflow - Cold water shutoff not working?
We had a bad overflow tonight. I did some troubleshooting by setting the machine at its max load and warm (hot plus cold) and found out that when the water gets to the shutoff point - the hot water is shutting off but the cold water is not. The tub fills to overflowing with cold water and we get a wet floor.
Any Idea what I need to replace?
  • not disclosed Jun 25, 2008
    I hooked a multimeter up to the contacts and I am getting resistance. I honestly don't know if I can clean this unit as it is sealed so I am going to roll the dice and bet that this is something mechanical. Checking on prices now.
    Just replaced the valve...27.99$ - not bad considering a service call would be 75$ just to come to my house.
  • 96 Answers
Sounds like the cold water valve is faulty. You can try to remove it and clean the inside if it's clogged or replace it completely.
Posted on Jun 25, 2008
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
Cold water will not stop running
I am assuming that you are having a problem with the cold water overfilling the machine. If only the cold water is overfilling and not the hot, then the fill valve is sticking.
If both hot and cold are contributing to the overflow when the washer is set to 'warm', then it is also possible that the fill valve hose (that goes from the tub to the fill valve switch) may be loose or disconnected (or possibly clogged).
Mar 01, 2011 | GE WWSE5240G
Cold water cycle has warm water no cold water allowed. sounds like some kind of valve is not stopping the hot water from coming in
Make sure that the inlet hoses are connected to the correct inlet solenoid valve (located just inside the cabinet). If the hot water solenoid was passing water when not wanted, the washer would eventually overflow on to the floor. There may be a problem with the solenoid control circuits which may require professional help to diagnose.
Feb 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Water in the expantion tank of my jeep grand cherokee seems to fluctuate between the max and min levels
This is perfectly normal.When cold it will be min. and when warm it will be max.Its the normal expansion of the radiator water and this is the overflow catch.When cooling down it will **** the water back in and not air.Hope this helps
Dec 31, 2009 | Jeep Grand Cherokee Cars & Trucks
Injector hose assembly overflows when filling hot or cold water selections only. Warm water filling does not overflow the hose assembly. Is this a bad injector nozzel valve or something else?
The injector hose is stiff from age, and the injector/anti-siphon assy is probably calcified.
Replace the Injector hose, and injector to tub hose (they usually fail right about this time and are relatively cheap), and clean the injector assembly with calcium remover and a toothbrush. The dole valve to injector assy hose should be fine.
Sep 07, 2009 | Maytag Washing Machines
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Hoover 500M Top Load washer - Water overflow & machine wont wash
Probably very repairable but impossible to say how much without looking inside and fiddling around and checking a few things.
Fault could be caused by several possible faults at widely varying cost.
I suggest you call a friendly local white appliance engineer...
Feb 13, 2018 | Hoover Nextra HNT 2135 Top Load Washer
Water overflow
when u replaced the sensor was it the round one that has a clear pipe going to it if ti wasnt u will need to replace it if it was then take the clear pipe off and blow down the pipe this will reset the wayer pressure sensor and should stop the washer from overflowing m8
Aug 19, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
287 people viewed this question
Dan Webster
Dan Webster
Sal De
