Question about Sony PlayStation 2 Slimline Console
Access codes When I put in certain movies, it ask for a code. I have never enter a code since I had it and it won't let me change it. Help
Enter 7444, then press Select. Next, enter your new code twice. An easy one to remember is 0000.
Posted on Jun 27, 2008
There was a parental lock code on our ps2 when we got it, is there a override code I can use to unlock it? I bought it at a yard sale last summer and they never mentioned that they put a lock on the DVD......
Try these directions, they *should* work.
1. Insert a DVD Movie into the PlayStation®2.
2. You should receive a message informing you that the Parental Level has been set, and asking if you?"d like to allow the disc to play. Highlight "Yes" and then press the X button.
3. A new window will appear asking you to temporarily change the Parental Control to a different level. Again, highlight "Yes", and then press the X button.
4. Another window will appear asking you to enter your Password. Above that window are numbers (0-9).
5. Do not enter your password, but instead, press the select button on your Controller. This will change the text in the window from "Enter Password" to "Delete Password".
6. Using the numbers above the window, input 7444. If successful, you will receive a message stating "Deletion Complete".
7. Press Select. You will now be asked to register a new password. Please select a four-digit code of your choosing.
8. You will be asked to confirm your password selection by inputting the same code once again. If successful, you will receive a message stating "Registration Confirmed".
9. Now you need to turn off the password altogether. The movie should of started playing by now. Press select and chose Setup. Go to the parental control "tab" and set the level to "off".
10. Now you should be able to watch any movie
Apr 05, 2011 | Sony PlayStation 2 (PS2) Console
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Bought a used ps2 and it has a password i can't watch movies due to the password
try the password 0000 it is very common. If not watch a movie with the lowest rating possible. then you wont need the password and when the movie is on you can change it somehow. or at least when it is in. I know ive had this problem years ago and i changed it somehow
Mar 11, 2010 | Sony PlayStation 2 Slimline Console
Nokia 3585 security code lost and how to unlock network ?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.nokiausa.com/get-support-and-software/product-support/nokia-3585
SECURITY CODE from page 54 of your manual:
Your phone prompts you for a five-digit security code for certain features and commands.
Access is granted only after the correct security code has been entered successfully.
The default security code is 12345. It is recommended that you change this code at once,
write it down, and store it in a safe place away from your phone.
Important: When entering your security code, ***** is displayed on the screen to
keep others from viewing your code.
You can delete the last entered digit by pressing Clear (or by pressing and holding Clear to
delete all the digits more quickly). Enter the correct code or press Back to exit. If you enter an
incorrect security code (Code error will appear) five times in a row, your phone won’t accept
any entries for the next five minutes.
Change your security code
1 Press Menu 4-5-2-4 (Settings > Security settings > Access codes > Change security code)
and press Select.
2 Enter existing (or default) security code and press OK.
Security and System settings
3 Enter new five-digit security code and press OK.
4 Re-enter your new five-digit security code for verification, then press OK.
Your phone displays the confirmation message Security code changed.
Important: If you change your security code and don’t remember the new code,
contact your service provider. Once you change your security code, the default code
is no longer valid.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 19, 2009 | Nokia 3585
I lost my code to watch movies
then it is your fault if you lost your code...
Jun 28, 2009 | Sony PlayStation 2 (PS2) Console
Over ride the parental control level
Ok first try 0 1 2 3 because that is the preset code for the ps2 or if that dont work insert any dvd movie, go to setup and access the parental control settings(press select) When asked for your code enter "7444"; It will prompt you again to type in your password. Type "0000" and then scroll down to the movie rating options and choose "off". Hope it helps you out!
Apr 10, 2008 | Sony PlayStation 2 (PS2) Console
Parental control password
i don't know if you changed the parental control code or not but when it comes to put the code press select and then insert 7444 and it will delete the password and will ask you to put the new one then add any three digit number and then when the movie starts press select and go to setup and then parental control tab and turn it off now there will be no passwords..........
Jan 16, 2008 | Sony PlayStation® 2 Console
PS2 PARENTAL CONTROL CODE
This is the only way to turn "off" parental control lock on the custom setup screen.
1) turn off ps2 with no dvd in drive.
2) turn on ps2 and insert dvd in drive.
3) when it asks about parental password, choose 'yes'.
4) when prompted for password, press 'select'.
5) the prompt will change and say 'delete password'. enter '7444'.
6) enter a new password (0000 works).
7) registration complete, dvd will start playing.
8) once the movie starts, press 'select'.
9) click the 'stop' icon.
10) click the 'stop' icon again (the icon must be gray even when you have it highlighted).
11) navigate to 'custom setup' ('select', setup icon, custom setup icon)
12) move to parental control option, press right directional button, enter password (0000).
13) move down to 'level'.
14) move up to desired level (off is at the top).
15) click 'x'.
16) go back to 'select' menu options, and press 'play'.
17) while movie is playing, eject disk and remove dvd.
18) turn ps2 off using switch on the back, keep off for five seconds.
19) turn on ps2, put dvd back in.
20) happy dance. ;)
Dec 25, 2007 | Sony PlayStation 2 (PS2) Console
Code deleting
mine used to do that as well. But I think code is set as default to 000 so just enter that when it asks.
Oct 11, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
