Question about Bose QuietComfort 2 Consumer Headphones
The bose quietcomfort 2 earphones
My bose quietcomfort 2 earshones are shorting out what do I do?
  • 1 more comment
  • BigMac42 Dec 10, 2008
    I  think the internal wiring has come loose.  At first the problem was intermittent.  Now it's dead.  No red light and no sound.   Has anyone figured out how to take the headset apart?
  • anooshaman Jan 01, 2009
    After I left the headphone on for a while it started making a loud short noises. I switched it off. Later when I wanted to use my QC2 headphone it was working intermittently, i.e. 2 seconds on 3 seconds off. Does this device have a battery or a fuse? If so how can I fix it. Anoosh
  • stratton6107 Jan 26, 2009
    tapping the left headphone causes the sound to short out
I've noticed a second or two of silence when bumping the headphone. In my case the battery was low and a fresh battery fixed this particular problem. Or maybe you have a poor connection.
Posted on Oct 28, 2008
Does it keep turning on for a second or two then off for a second or two? Mine have been doing that, and I think it is in the left headphone when it gets bumped, but i don't know why.
Posted on Aug 15, 2008
How won't my new headphones connect with my I pod through bluetooth
In most cases this is because the new owner didn't read the instructions.
When you turn on Bluetooth on the iPod and click Search, you have to press something on the other piece of equipment to send the signal TO the iPod. Once they find each other, they connect automatically after that.
However, we have a problem. Your headphones Bose Quietcomfort Qc15 don't appear to be Bluetooth enabled! You have to connect with a lead.
http://worldwide.bose.com/library/assets/pdf/guides/headphones/qc15/en/owg_en_qc15.pdf
manual is also here
Bose QuietComfort 15 Owner Manual Page 4
Jul 20, 2016 | Bose Quietcomfort Qc15 Acoustic Noice...
Rattling in left earcup
Sounds like you have blown out the cone on the speaker. Have you removed the covering to see if the speaker in that earphone is intact?
Feb 10, 2014 | Bose QuietComfort 15 Headphones
How to replace ear cushion on bose QC 3 headphone
The ear cushions are held on the earcup with six snap fasteners, three on each side. To remove the ear cushion, simply pull it away from the earcup carefully so that you do not break the plastic snap tabs.
It should not be necessary to pry the ear cushion off with a sharp object, but if you do, be careful. There is also a thin gasket seal between the earcup and the ear cushion, take care not to damage it.
If you need to replace the ear cushions with new ones, they are available from Bose for $35/pair.
QuietComfort 3 Acoustic Noise Cancelling Headphones Bose Product Support
They are also available aftermarket at Amazon.com for $16.99/pair
Replacement Earpad ear pad Cushions For Bose QuietComfort 3 QC3 Headphones...
or $5.69/pair.
Bluecell Pair of Replacement Earpad Ear Pad Cushion for Bose Quietcomfort...
Apr 02, 2013 | Bose QuietComfort 3 Acoustic Noise...
No sound from right earphone
Your cable is cut / disconnected / damage. Please try another good headset
Feb 26, 2011 | Bose ® QuietComfort® 2 Acoustic...
Only left earphone is working
You should return them to the place you bought them. They should be able to sought the problem out. You might need the sales ticket. Or visit the Bose website. They should have telephone number helpline.
Jul 09, 2010 | Bose QuietComfort® 15 Acoustic Noise...
Regardless of the audio source I connect my Bose QuietComfort 3 Headphones to, I can hear a small amount of static, especially at lower volumes. I have used another pair of headphones to test the devices...
Hello and Welcome to FixYa!
Yes Sir, as you have cross checked the audio so other possibilities have been ruled out, the only problem can be with your Head Phone unit, usually what happens is somewhere from inside the wire get cracked, or short resulting in noise or static, so the solution is to replace the wire, but the unit is a delicate thing so I'll never advice to D.I.Y.
I hope you have a clear picture now,
Regards, Waqar.
Oct 10, 2009 | Bose QuietComfort 2 Consumer Headphones
Left earphone just stopped working -
I just solved my problem. My left earphone wasn't working or would work some of the time with it cutting in and out depending on my head position or if I moved quickly. What I did follows:
1. Took ear pad off
2. Took black liner off of the inside of earphones. Glued on 2 spots.
3. Below the silver band of material is a clear plastic lining that covers the speaker.
4. I pressed that clear liner to see if it helped make the left earphone work and it did.
5. I had to fiddle with it to get it perfect but it worked for me.
I'm sure this would void any warranty and work on your own headphones at your own risk.
Aug 26, 2009 | Bose QuietComfort 2 Consumer Headphones
Less sound on one ear than the other
Yeah, based on all of your problems, i would safely say that you have a blown speaker. Call up Bose at 1-800-999-2673. If the headphones are under warranty (1 year) they will replace them for free. If now, they will charge you $100 for a replacement pair, which is quite a deal considering that the headphones cost $300.
Jul 05, 2007 | Bose QuietComfort 2 Consumer Headphones
Bose QuietComfort 2 Consumer Headphones Logo
1,079 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
