Question about Intertherm Heating & Cooling
Air conditioner not working.Tries to come on but doesn't. Blower and heat unit works fine. Model E1EB-010HA Nordyne. You can hear humming at outside unit.
    Scholar:
  • 104 Answers
Most likely a failed run capacitor in the outdoor unit. The unit either has two separate run capacitors; one for the outdoor fan and one for the compressor. Or it may have one dual run capacitor which is the two capacitors built into one casing. Usually either a grey or silver cylinder with terminal connections on one end. If you intend to replace, make sure the power is off first by pulling the disconnect or turning off the breaker. Mark all wires and make sure they get back to the same terminal on the new capacitor. Capacitors are rated by their capacity (go figure) the new cap must match the old cap exactly on the uF or MFD (called micro-farads) rating. Voltage rating on the capacitor must be 370v or higher (most new caps are 440v rated). If you are not completely comfortable doing this yourself, a qualified HVAC service company can take care of the problem for you.
Posted on Jun 25, 2008
MY outside unit will not kick on now I just had it filled and seem to not want to kick on so I'm thinking it a short or the new t-stat that was just replace over the winter heat side works fine
Turn breaker off. Wire nut the red, green and yellow. Turn breaker on. Check outside. If unit is running either your tstat is not setup properly or it is bad
Jun 17, 2016 | Intertherm Heating & Cooling
Wiring diagram for electric furnance model E1EB-015HA
THIS IS THE WIRE DIAGRAM FOR THE NORDYNE E1EB-015HA UNIT.
Feb 14, 2012 | Heating & Cooling
Model Number: UACC-036JAS The unit works fine. The problem is it doesn't shut down after the specified temperature has been reached. The furnace blower shuts down, but the ac unit keeps on running....
Hello, usually a stuck contactor coil will cause this on the outside unit. When the outdoor unit runs continously and the indoor blower does not run no heat is being absoebed by the evaporator coil and thus the line freezes. Replaceing the contactor will fix the problem.
Aug 30, 2011 | Ruud Heating & Cooling
No voltage to thermostat inside blower does not come on and ouside unit does not come on. Nordyne/intertherm model E1EB-017HA
Check the breaker or fuse's then check power supply to the transformer you shuld get 24 volts out of it..
Aug 05, 2011 | Heating & Cooling
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
I need a wiring diagram for a intertherm model # e2eb-015,017
Intertherm is Manufactured by nordyne Inc.
Id recommend www.nordyne.com
At least they could get you to the write people that may have the info you need.
Good Luck!
Nov 03, 2009 | Intertherm P3RC-030K Air Conditioner
Heat pump not running
check your house circuit breakers first that should be labeled heatpump or outdoor unit
make sure it is on and or not tripped
then if you have a box outside near the outdoor unit open it up and see if there is a breaker or maybe fuses that could be blown
May 26, 2009 | Goodman CPLE24-1 Air Conditioner
Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Apr 11, 2009 | Heating & Cooling
Need a schematic for nordyne intertherm model e1eb-015ha
Nordyne no longer has the E1 model in there literature not even in their archieved documents but I have included a link to for the E2 model which will be very similar to yours. These units are very simple and all only vary slightly. It should give you enough info to get you through what you want to know.
http://www.nordyne.com/literature/7103180.pdf
Apr 04, 2009 | Heating & Cooling
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
160 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
