Question about JVC GR-AX970 Camcorder
Capturing video through my PC
During playback everything you see in the viewfinder is captured on the new video created on my PC. The tape counter,battery,TBC, etc.
Please tell me how to remove all these little pictures during playback and my capturing process, so I can have a clean movie.
infohere1@gmail.com
Manual can be found here http://camera.manualsonline.com/manuals/mfg/jvc/gr-ax970.html
Thank you so very much
2 Suggested Answers
SOURCE: JVC GR-DVL300u
get out of safeguard mode
Posted on Apr 14, 2008
VC500 - Arc Soft Biz capturing problems
Using old tapes is the wrong way to go. Eventhough there is an rease head in the VCR, there will always be some residual information left behind that affects the new recording. Older tape also has a tendency to flake off and plug a video head. A tape with a wrinkled edge will confuse the recorder speed sensor and try to change speeds too.
Dec 23, 2013 | Diamond Multimedia ( VC500) Video Capture
When I capture video from vhs, the result is a lot worse in quality than the original tape. I have tried capturing avi and mpeg, it makes no difference. fixed bitrate at 8000, no difference. Highest...
If you have the option, try capturing your video as MJPEG or DV format without compression, also the resolution must be 720x480 pixels (for NTSC) or 720x576 pixels (for PAL).
It will create a huge file !!! After this I recommend a dvd conversion with deinterlacing for better picture quality.
Hope this helps!
Oct 07, 2010 | DekCell EasyCap USB 20 Video Capture...
Panasonic NV-GS27 playback
you can playback only when you connect it to a pc tv tuner card. or other video editing or capturing software installed for camera
Jul 01, 2009 | Panasonic NV-GS27 Mini DV Digital...
Vedio capturing tool
Hi, Use Window Movie Maker.
Open Movie maker while the camera (on) is connected to the computer. Click on Capture video from device and follow the steps. Look out for any options like create clips and disable them.
Nov 16, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Dropped frames during capture from camcorder
Firewire cards are quite cheap, under $20, replace the card. If you still have problems then it is most likely with the camcorder.
Jun 05, 2008 | Canon ZR830 Mini DV Digital Camcorder
Playback
Not really a solution. But I find a bit of blank tape and record for a few seconds. Stop rewind and for some reason it clears the black lines. Until the next time. Pain but it works for me.
Jimmy
Dec 23, 2007 | Panasonic NV-GS11B Mini DV Digital...
Computer mode
hi follow this steps: Make sure that you have installed the USB driver for the handycam. You can download the drivers from this link: Sony Asia Pacific Support Website--Download Page for HC40E USB Driver for Windows. Connect the handycam to the AC adaptor (the same as putting it on charge). Set the handycam to USB stream mode. (Press P-menu, press MENU, Press EDIT/PLAY, Press USB MODE, Press USB Stream.) Set the tape at the point from where you want to start capturing in PC. Connect the handycam and the PC with the USB cable. (USB-Mode appears on the handycam LCD / viewfinder.) Start Windows Movie Maker. Click on the 'Capture..' link to start the wizard. Select the Sony Digital Imaging Device. Click Next. Specify the file name and path for the capture video. Click Next. Select the desired capture format and Click Next. (Leave it to recommended setting if you are not sure.) The dialog box now displays the Start Capture and End Capture buttons on the left and preview window on the right. Play the tape on the handycam. The video from handycam should appear in the preview window of WMM. Click the Start Capture button to start capturing the video. Click End Capture to pause or stop recording. Click the Finish button. The .wmv file will be saved in the path specified in step 7.
Oct 02, 2007 | Sony Handycam DCR-TRV265E Digital...
Problem capturing footage from Canon MV700 DV camcorder to Windows XP
I use Pinnacle Studio versions 9 and 10 without any problems. The software sees the camera MV700i and controlls the playback etc. Have also used Ulead Movie Factory without any problems, but its a little harder when it comes to editing the output.
Jun 19, 2007 | Canon MV700 Mini DV Digital Camcorder
Digital Video Output
repairs up to 50 % of replacement cost are reasonable , if warranty is same as new ( if warranty can be extended - resale improves ) ;
Jan 12, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony DCR-TRV230E Digital 8 Playback Problem
Hi! If the images you are capturing are hazy with zig zag colors etc...the imaging IC is faulty.If the problem in Display unit only but the captured image is OK when you transfer the same to PC..then LCD may be having problems. We can help you in spares of Sony and we can also offer the service manual. Kindly let me know after your examination. Regards, Sivaram.V Videolabs
Nov 28, 2006 | Sony Handycam DCR-TRV240E Digital...
JVC GR-AX970 Camcorder Logo
20 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
