Question about Sony Playstation 3 (PS3) Console
Won't play games
My play station takes the disc, but the turntable doesn't start spinning and the laser does seem to hunt for info. This was an intermittent problem. Now, the disc motor won't turn on.
  • Anonymous Jun 25, 2008
    the disc spins for at the most 30secs then stops....it doesnt play any games...and the one that plays displays an error (8001002b)....how can i fix this? do i have to take it to sony?
  • SAM LEES Jun 25, 2008
    My playstation will not load up the games i just got metal gear solid and just got on the story mode n it crashed so i reset the ps3 and it will not find eny of my games or dvds or nothing very very p e e e e e d off
We had a similar problem with our PS3. Called Sony tech support and they walked us through several troubleshooting steps, but couldn't get it to read a disc.
Go to the Playstation Forum: http://boardsus.playstation.com/playstation/
In the "Search" box, type "will not read disc" and you'll find others with similar problems.
If your PS3 is under warranty, they'll likely have you ship the old one back and they'll replace it. Unfortunately, that means you'll be without a PS3 for 3-4 weeks. Good luck.
Posted on Jun 25, 2008
Pes 2013 for play station 2 won,t start
The game is for the PS3, not the PS2, which means it won't play on an older system.
Mar 06, 2013 | Konami Pro Evolution Soccer 2013 for...
My blu ray player won't play the hunger games
Need more info. Does the player accept the disc? If so, do you hear the disc spinning inside? If not, what does the player do? Does it kick the disc back out? Will this player accept and play other discs?
Sep 10, 2012 | Sharp Aquos Bd-hp22u 1080p Blu-ray Disc...
Hi,the disc in my play station 3 won t come out,it just keeps spinning when you push the exit button
If you have this problem it is because the laser has shifted from where it needs to be and the good news is that it is not that hard to fix all you need is a good repair guide.
You can of course send it in but the disc reading issue you should be able to fix in less than 1 hour from home.
Check out this link for a full explanation:
PS3 Not Reading Games
Hope this helps?
Sep 27, 2011 | Sony Playstation 3 (PS3) Console
My playstation 1 won't play any games. It will start up with the disc spinning but then the disc stops spinning and i end up on the memory card screen.
DEAR FRIEND CHECK YOUR PS LANCE EYE AND CLEAN I HOPE READ PLY STATION LOGO THAN NOT PLAY , CHECK YOUR PCB BORD RBI CHANGE THAN REMOVE YOUR PROBLEM I HOPE SOLVE YOUR PROBLEM TACK CARE
Aug 21, 2011 | Video Game Consoles & Games
When i put in a dvd into my player, it says no disc, and won't play, when it does accept the disc, it doesn't play it, then a "C:13:00" starts blinking. I should be able to just put in a...
It's most likely dirty, though it could be failing. The lasers have an average life span of 3 years, under normal use.
Several companies make CD/DVD laser lens cleaners. You want the kind with optical quality brushes on the bottom side. You simply put it in, let is spin up and play, then take it out. It may not play the first couple times you put it in, but it will be cleaning the lens and pickups.
If that doesn't do it, I'd start looking at sales for a new player.
Jul 05, 2011 | Sony Televison & Video
My play station doesn't recognize dvds or games I put them in and no icon comes on and it doesn't paly
The Playstation 3 is a wonderful video game console, however, with heavy usage, the laser does eventually burn out. The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the game will stop reading altogether (even though movies sometimes still work). Eventually movies will stop working and the whole laser will eventually die.
The following website sells PS3 lasers and also performs repairs:
http://store.richspsxparts.com/pl3isnotrega.html
Jun 17, 2011 | Sony Playstation 3 (PS3) Console
The game starts but it cuts off and say wipe the disc and start the console over..The game disc is brand new but it wont start the game
Well it's a defiantly a hardware failure
90% of the time installing a new laser
will fix it . New laser are cheap 20.00
10% the one of the two motor will fail
so you'll have to buy a new drive and
swap the P.C. board form to old drive
to the new , both are relatively easy
procedures. DON'T WASTE YOUR MONEY ON REPAIR
GUIDES . all of the info you need is free on line.
A little extra info
Rob
Dec 28, 2010 | Microsoft Xbox 360 Console
I have Sony playstation 2, on connection to LCD it is asking insert play station format disc, what to do?
Seems that it is not recognizing the disc.
You have a few options:
1. Take it to someone to repair
2. Take the system apart yourself and try cleaning the laser
3. Try adjusting the POT on the laser (small screw on the laser that can be turned)
4. Replace the laser altogether.
Jun 24, 2010 | Sony PlayStation 2 (PS2) Console
WHEN I TRY TO PLAY A PLAY STATION 2 GAME IT WILL READ THE DISC THEN AUTOMATICALLY STOP READING THE DISC
i had this problem its 1 of 2 things your engine is on its way out or your laser is on its way out take it to a console repair shop to get it repaired
Apr 30, 2009 | Video Game Consoles & Games
CDJ 800 Bad Laser
Yes, sounds like you have a bad traverse assembly (laser). You can replace it yourself, however, I wouldn't suggest it, as you need to calibrate the assembly after the installation, and remove a solder bridge (which keeps the unit safe during transport). It is a little complicated, if you don't have experiencing doing this type of work. Taking it to a service center would be your best option.
You can purchase the part HERE
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 17, 2008 | Pioneer CDJ-800 Turntable
Sony Playstation 3 (PS3) Console Logo
113 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
