Question about Dryers
I have a gas dryer lge5966w that tumbles but does not heat. I checked electrical & checked gas - both okay. I do not hear spark nor gas ignition.
  • 525 Answers
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
If this doesn't help, post me back and I will do some more research to help resolve your issue.
http://www.repairclinic.com/0088_8_1.asp#Level1_14
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse).
A less often failure of the cycling or hi-limit thermostat could inhibit ignition. Also make sure temperature switch selectors have been set to a heat position.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 25, 2008
LG dlg2526w gas dryer lp no heat but it tumbles
The first thing you need to check is that the gas line is on and you have electricity to the machine. The next step is to open it up and check the ignitor, since that is a high failure item on your machine, that is where I would start.
Jan 17, 2012 | Kenmore Dryers
My dryer is tumbling & blowing & all the cycles seem to work but it won't heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Frigidaire AEQ8000FG Dryer
My LG tumble dryer does not heat up, the motor runs and everything tumbles inside but it does not heat up. what could be the cause of this?
heatman101\]]\]\
Aug 16, 2011 | Dryers
Dryer tumbles but does not heat up, there is little heat when it tumbles without any cloths in it.
heatman101
Aug 11, 2011 | Dryers
I have had a stackable hi efficent 7.3 cap. kenmore dryer for 2 months. Suddenly it doesn't heat. No sign of vent problems or electrical but on all cycles both the dry & cooling light up at the top...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Kenmore Dryers
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
My tumble dryer is going round & seems to be working just no heat so no dry clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 14, 2010 | Dryers
GE Profile gas dryer tumbles but NO HEAT, not ignitor
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer not heating...tumbles and blows OK - is 2 30 amp fuses enough
ELEMENT IS BAD NEED TO HAVE A SERVICE TECH REPLACE THE HEATING ELEMENT
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Gas dryer tumbles no heat.
I would change out the igniter, When they start failing hey will glow but not draw enough amps to open the gas switch / valve.
May 02, 2008 | Dryers
Dryers Logo
137 people viewed this question
Top Dryers Experts
