Question about AGA Kitchen Ranges
Indicators is there a known issue with the indicators,, ill tell you that theres a range i am working on and they stay barely lit when off and when you unplug one side of the indicator they go off but hook the wire back up and check voltage and its 120 volt on one side and then power it up its lites up good and then turn it off again its barely lit so i unplugged one side of the indicator from the selector and thermistat and it still lit a little and that wire is unplugged isnt connected to any thing but the indicator so i pulled the wire from the indicator and it isnt lit. any ideas.
  • 631 Answers
SOURCE: my kenwood kac7201 amp wont turn on but it has power to it
Recheck the voltage precisely like this:
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 22, 2008
voodoomox
  • 1689 Answers
SOURCE: Green power light is off. Red light stays on. Tried unplugging, resetting, etc. Wondering if it's completely shot?
Hi Jeff,
Thanks for using fixya
The red light on power means that the diagnostic for the modem is on, and when this is on this means that the memory or another component of your modem is at fault. Usually this can be resolved through a firmware upgrade to be applied by 2wire, but note that 50% of the time, when the diagnostic light is on, the device is dead.
To have this issue resolved, you may refer to your ISP or 2wire, if it cannot be revived, the least they can do is provide a recommendation.
http://support.2wire.com/
regards,
voodoo
Posted on Apr 22, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Posted on May 30, 2009
  • 21 Answers
SOURCE: battery will not charge on a dell d610 when plugged into outlet
I have seen this with faulty batteries.
Try changing the battery.
Also, check in the BIOS that the adapter you are using is recognised and shows a state of charging with the battery in.
Posted on Jun 25, 2009
  • 8 Answers
SOURCE: toshiba TP43H95 projection tv has power but no picture
If it shuts off and then the power light starts blinking red or it never comes on but the power light just blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them. Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: missionelectronics@sbcglobal.net The cost is 375.00 and that includes parts.
Good Luck.
Posted on Jun 26, 2009
I have a ceramic top slide in range. The clock will light up when the clock button is pressed but will not stay lit. Timer works and all oven controls work as well as the cook top and oven. Any...
Hi Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing, it appears your Frigidaire range is possibly experiencing a potential wiring failure or a communication problem with the EOC (Electronic Oven Control). Try unplugging your range or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and then turn on your range. If the issue continues, then I recommend contacting a professional to make a precise diagnosis.
May 21, 2014 | Frigidaire 30" Self-Cleaning Slide-In...
Surface stays lit
If it's unplugged, and something is lit, it must be on a battery, like memory for the clock or something.
Nov 22, 2013 | GE Spectra JBP78 Electric Kitchen Range
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
I've misplaced my users manual for my Stanley J5C09 jump starter
Go to www.baccusglobal.com and link the Stanley link and then the "manuals" link and it should be there
Dec 27, 2010 | Stanley Black & Decker Stanley J5c09 500...
Screen goes black
I think your battery might not be shorting out the lcd.
Leave the battery out and see if the lcd stays lit without going black, if it does it probably is the battery thats bad.
Try a known good working battery and see if the lcd stays lit. If the lcd stays lit then you know the battery was bad. if you get the same symptoms from another battery then you know its something with the motherboard at that point.
Jun 20, 2009 | Toshiba Satellite A45-S151 Notebook
Vic
May 30, 2009 | Kitchen Ranges
Frigidaire slide range clock will not stay lite
I have the exact same problem. Timer works and stays lit, but clock will not stay lit. Any answers?
Mar 05, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
Surface unit indicator light is always on
One set of contacts in a surface unit switch is "welded" together, causing the burner indicator (pilot) light to remain on even when all burners are shut off.
With power disconnected to the range, remove the back cover behind the switches and pull one of the wires going from a surface unit switch to the indicator lamp. Make sure the bare wire is not touching anything and reconnect power. If the light goes out (and still goes on when the other burners are turned on) you found the bad switch. If light still on, repeat the procedure with another one of the burner switches (reconnecting the first) until you find which switch is the bad one. (most often it is the burner you use the most, generally the right front burner) If you post your full model number and tell me which switch it is, I can look up the part number for you.
Feb 06, 2009 | GE Kitchen Ranges
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kitchen Ranges Logo
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Paul Carew
Tom Chichester
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
