Question about GPS
ON MY LANDAIRSEA GPS TRACKING KEY..WHEN I TRY TO DOWN LOAD, I GET EITHIER 1. PLEASE RECYCLE UNITES POWER & TRY AGAIN. OR 2. DOWNLOAD DOES NOT SEEM TO FINISH NORMALLY....IT DOWNLOADS REAL SLOW,THEN SHUTS OFF
  • 796 Answers
You need to take the device to the service centre and the will reprogram the tracking device..
coz only the company will be having the necessary hardware and software
Posted on Jun 25, 2008
When I turn my Garmin 550 on it says loading maps, then goes to the select a local: It's frozen their on United States i push OK and nothing happens can not change the Locale it's frozen I tried...
Hi tkfranks331,
Press the power key and hold it if the screen of your Zumo is frozen. Keep holding the power key while pressing the key that has a plus symbol ("+") on it. This will reset your device and unfreeze the screen. You can also try calibrating the screen by pressing the power key for one full minute.
If this does not work, please follow these steps.
1. Update the internal disk software. Download and install WebUpdater on the computer. Please visit this link to download the WebUpdater.
2. Open WebUpdater on the computer.
3. Connect the Zumo 550 to the computer with its USB cable.
4. WebUpdater will automatically search for updates.
5. Follow the prompts to download any pertinent updates for the Zumo 550.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Garmin zumo 550 GPS Receiver
Quest unit not accepting map info
u need a firmware update i think
Mar 21, 2008 | Garmin Quest GPS Receiver
Gps is only accurate within 100+feet while geocaching. Problem started just in the last month before that it was dead on. I've replaced battries and recalibrated but still no good.
The GPSr needs to build a new almanac. There are a few steps to do this properly.
1. hook up your Garmin to your PC and copy your wanted files. (Waypoints, geocache log, maps)
2. Do a soft reset of the GPSr.Warning: This procedure will delete information (waypoints, routes, tracks, etc) from your GPS and settings may be set back to factory defaults.
1. Power the unit OFF
2. Hold down the two Soft Keys for 2 seconds
3. While continuing to hold the 2 Soft Keys down, press and hold down the Power button for an additional 5 seconds
4. Release all buttons, and select YES to the prompt asking "if you want to clear all user data?"
This form of reset does not seem to reset all of the settings to factory defaults, just a few of the basics like Time Zone and Language, the remainder of the settings are still taken from your existing profile files.
for this
3. Build a new almanac (Make sure you have fresh batteries)
Once you have completed a reset remember to place the Colorado outside in a stationary position for 20 minutes in plain view of the sky so that it can rebuild the almanac before using it again.
Feb 03, 2011 | Garmin Colorado 400t
Code to unlock a kenwood dnx5140 car gps sterio
ype 1
  • During the code request mode, while pressing the DISP key, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
  • Enter the security code with the Kenwood remote.
Type 2
  • Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
  • Press and hold the 1 then the 6 preset keys until the display shows the letter C.
Entering Letters with a Kenwood Remoteo enter a letter with a Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter. Press the Track Up or Next Track key to send the letter. To send the letter A, press the 2 key once then press the Track Up key. To send the letter B, press the 2 key twice then press the Track up key.
Finally, when all of the letters are entered, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
  • 5
  • 5
  • Track Up
  • 2
  • 2
  • 2
  • Track Up
  • 2
  • Track Up
  • 7
  • 7
  • Track Up
The Kenwood should then enter tuner mode.
A Security Code Bug in Some Kenwoods
Oct 31, 2010 | Kenwood DNX5140 Car GPS Receiver
Garmin 755t tries to power up -says loading maps then recycles in a loop
You need to upgrade your software download the Garmin software hook up USB, to Garmin and connect to the Garmin website then you will be able to download software and fix your unit.
May 02, 2010 | Garmin n?vi 775T Car GPS Receiver
Gps will not start up
Hello :
I recommend you to reset your device to fix the problem .
Here is how to reset your GPS :
1. Turn unit OFF
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
Here is how to hard reset your GPS . But be careful because Hard Reset (Deletes stored GPS Data such as Waypoints and trails)
1. Turn unit OFF
2. Press and hold the ZIN&ZOUT Keys at the same time
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Lowrance LCX-15MT GPS Receiver
Turns On but not past the loading screen
Hello :
I recommend you to reset your RoadMate .
To reset your RoadMate please follow these steps :
1: Locate the button marked "Reset" on the left, right or bottom of the unit.
2: Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
NOTE : Please don't attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
This solution should help with your problem . If that didn't help , then I recommend you call Magellan service for help .
Apr 16, 2010 | Magellan RoadMate 1340 GPS Receiver
I connected my Navman S80 to my computer to charge it and in the meantime I was clearing old files. I accidentally deleted everything from the S80 and emptied the recycle bin. Is there any way to get the...
have you not got a set up disc ?? if lost try emailing navman for new one or down load, check if you have only switched the functions off on gps unit or search pc if old file in in the desktop
Dec 26, 2009 | GPS
Not tracking
Reset the unit by clearing the memory. Hold the RIGHT ARROW key and press the POWER BUTTON, while holdingthe RIGHT ARROW key until the DELETE MEMORY screen appears. Select YES and press ENTER. Then procede to initialize the GPS. Leave it outdoors for an hour or so to acquire satelite feed.
Apr 20, 2009 | Magellan GPS 310 GPS Receiver
Connecting Garmin Foretrex to PC
Hi, I just wanted to let you know that I have been having problems downloading the wayponts but not the tracks. I use Street Atlas USA and have NO problems downloading all data with my garmin GPS12. I notified garmin about this problem. To see if your gps is recieving data try using the geocaching.com web site. Sign up [ it is free ] and click on an icon cache in yoir area, then click on send to gps. You will be prompted to download free software to use it. Once it is installed, try the above option again. You will get a menu that shows devices shown. Look for the fortrex and send it to the gps. Make sure your gps is in " GARMIN " mode for the interface. If it shows your fortrex then it is communicating with it. Download the cache to your fortrex and then look at it in the waypoint file of the gps. The web site is :http://www.geocaching.com/
Kevin
Oct 25, 2008 | Garmin Foretrex 101 GPS Receiver
GPS Logo
52 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
