Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Electric range F1-1 persistant fault code
I have replaced both upper and lower termperatature sensors on my Maytag dual oven but the F1-1 keeps coming back after a few days.
Any ideas on what to do next?
  • 15,935 Answers
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
#$%^Y
Posted on Oct 01, 2010
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Received an error code F1-2. also both of the ovens will not heat.
The F1:2 error code means that the LOWER OVEN tempature was way to high..this is usually caused by a defective oven temp.sensor.
The LOWER OVEN sensor would need to be checked,to check the sensor isolate it from the wiring and check for between 1060-1100 ohms of resistiance at room temp. if it's not pretty close to that range either way +/- the sensor is bad and needs to be replaced.
By pushing clear/off button it should clear the code and you should be able to use the small upper oven.
Aug 28, 2011 | Maytag MER6772 Gemini Electric Kitchen...
MAYTAG GEMINI model MER6770AAW Fault code F1-L -same code for upper and lower. After reading other comments, it appears that the temp sensor(s) are bad. I need to find part #'s and cost. Thank you Pete
Here's a late response, hopefully helpful to someone... I had the same issue with same model Maytag range. I pressed the CLEAN option on the touchpad (bottom oven) and that option seemed to work. I pressed Auto Set and I let it go through "remove oven racks" until the display panel read 100 degrees and then pressed CANCEL. About 30 seconds later, when the oven was out of "clean mode," I pressed BAKE, then Auto Set, and it's been working fine ever since...
I'm sure the sensor needs replaced and will go permanently sooner or later, but if anyone out there gets the F1-L code but hopes to at least temporarily revive your oven maybe this will do the trick.
Feb 15, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
MER6770 Fault Code
No. just the one sensor part number 12001656. After paying a maytag repairman twice, I will now for the third time replace it myself, google the part number and you will see the different companies that sell it. Price runs up to 40.00, next time buy a different product and hope that Maytag goes out of business!!!! I know I will!!!
Dec 17, 2007 | Maytag MER6772 Gemini Electric Kitchen...
F1-2 fault code persists after sensor replaced
Sensor is about 40.00 I would recommend replacing it yourself. Part number is 12001656 google the part number for places to purchase it. If you use maytag you will pay through the nose!! I have payed twice now! Control panel is part number 74006213 that runs about 200.00 to 290.00 that is probably not your problem, you just had another bad sensor installed. Maytag doesnt care, they already got you when you bought it!
Nov 19, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
The oven temp sensor has gone bad.  F1-2 would be for the lower oven and F1-1 would mean the upper oven.  If you give me the model # from the sticker on the oven I can direct you to a diagram, part #, and price.  These are very easy to replace.  Should be located inside the oven in the upper right or left hand side.  It looks like a silver rod about 4-8 inches long and crimped on the end.  Most of them can be removed from inside the oven by removing the two screws, pull out the sensor (harness and all) plug in the new sensor, put the screws back in and your done.  Some have to be removed from the back of the oven by removing the lower, larger back panel and follow the same process as mentioned above.  Hope this helps.
Oct 19, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
233 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
