Question about Toshiba TZ55V61 55" Rear Projection Television
Resetting power When I power the T.V. on it clicks twice and then the red power light begins flashing. We have tried unplugging it and plugging it back in but it continues to do the same thing.
  • jmmmreilly Jul 12, 2008
    I have the same symptoms. It seems ironic, though, that this happened during a time when my city was digging a new sewer line, cut my cable line, patched it, then damaged it once again. No other TVs in the house were affected, no other electrical devices.
    I, too, have tried unplugging the TV - overnight - with the same blinking LED results.
    Are there any reliable online stores to inexpensively purchase a new power supply?
I think your problem is actually simple enough, but may require proffessional service, depending on your fundamental skills with electronics. It sounds most likely that your power supply is bad. This would explain why this happens at the begginning and not later on. You see, once the transisters are warmed up, it is not so demanding on thepower supply. You may want to have it proffessionaly done, which may cost about 300-400 dollars. This is a good tv set, so it may be worth it to you, but I would suggest you look around at replacement costs and determine if you want to gamble with it. Good luck.
Posted on Jul 08, 2008
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
Panasonic cinemavision 1080i power light blinks red twice, will not turn on
The clicking sound is a safety device that prevents that TV from starting because a fault has been detected.
The fault is also indicated by the two blinks. Two blinks point at a problem with one of the low voltage lines (it should be 15V) from the power supply. The PSU is the part to be tested and eventually replaced. Before calling the technician try to unplug the power cord and leave the TV to rest for about one hour before restarting.
Nov 18, 2013 | Televison & Video
My panasonic th-50px60u television turned itself off last night and won't turn on makes clicking noise when unplugged and plugged back in but then nothing red light flashes
Tries tv unplug,replug it back like about an hour later for the tv to do it resetting itself back to the factory setting,tv might work again.If not still same problems.The tv 90-95% it is the board that call the tv power supply board is having a problems.That the board where the tv power a/c cord plug into it.U have all tools and know basic electronic and also can do basic soldering works too?Yes,take the tv aparts,check the tv power supply board carefully for dying and soon to be dead capacitors components parts.These capacitors components parts are alway bulges up or puffing up onto it tops.These dying and soon to be dead capacitors components parts are bulges or puffing ups on to it tops must have to be replaced will solved ur tv power unstable and flashing red light.Or try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 29, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
My panasonic Th50pz85u will not turn on. I can hear a click and the red light next to the on-off switch flashes twice and continues this flashing twice sequence. When this first started a month ago I could...
U know basic electronic?Can u do basic soldering?U have tools like a soldering iron,desoldering pump or desoldering braids,solders?The power supply board have parts that call capacitors,it dying,that why is causing this problems.The power supply board,that the board,where the power a/c cord plug into it.These capacitors on power supply board it dying,will bulges up on it tops or puffing up on it tops.These dying capacitors are now dead,must be replaced to solved this flashing twice problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 18, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Standby button (red) flashing on tv. tv turns on briefly(no picture) and then turns off with flashing red light re-appearing.
Try tv unplug,replug about an hour later.The tv now,resetting to factory setting.The tv now,should work.Not than,the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 08, 2010 | Sony BRAVIA KDL-40V3000 Television
Tree lights in red
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
PT-56LC27 52
If the light flashes red 2x's its a problem with the lamp. That's all I know. It's happened twice to me.
Dec 18, 2009 | Panasonic Televison & Video
TV won't turn on, red light flashes twice
your tv has hardware problem and Sony service person can fix it.
Jul 16, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Power problem
1)all TV's I service get the chassis pulled for good visual inspection and soldering any/all suspect connections,esp. any
active device mounted to a heatsink.
2)Check horiz drive circuit for weak capacitor.
3)Let me know if you are still on it.....T.
Oct 24, 2006 | Toshiba TZ55V61 55" Rear Projection...
Open Questions:
Toshiba TZ55V61 55" Rear Projection Television Logo
324 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
