Question about LG DLE5977 Electric Dryer
LG 5977 dryer makes grinding noise
Grinding noise begins as the unit is turned on. Had it for almost 3 yrs. Discoloration/brown color on the heat source grid inside the tub. Check filter indication is on eventhough we had it cleaned very well including the vent from the unit to the wall.
Any help is greatly appreciated.
Thank you.
  • 3DragonFly Jul 04, 2008
    Is there a step by step process to take the LG Dryer apart to fix the problem?
    I appreciate your help greatly.
  • mreilly55 May 24, 2009
    I have the same problem and took apart the machine today.  I found a torn gasket that is glued to the tub.  When the tub rotates there is metal on metal contact where the gasket is torn causing the sound.  I am now trying to figure out if I should order a new gasket or the whole tub assembly.  The gasket is around $20 and the tub assembly is $120.  If someone could tell me what type of glue to use on the gasket and how to install it properly I would simply pay the $20 and get the gasket.
  • 525 Answers
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
http://www.repairclinic.com/0088_8_1.asp#Level1_7
If your dryer is noisy, check these: (Click on links).
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it. If this doesn't help, post me back and I will do some more research to help resolve your issue.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 25, 2008
Dryer makes loud grinding noise when heat turned above low.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 18, 2011 | Amana Dryers
When you start the dry it makes a loud grinding sound. The drum still turns but seems to turn harder.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 14, 2011 | LG DLE2512W Electric Dryer
Dryer is making loud grinding noise when in use. The sound is more prominent when loaded. Model # LDE9304ACE, well over 10 yrs old. Is this noise my motor or my pulley?
heatman101
Feb 01, 2011 | Maytag Dryers
Dryer making loud screeching noise LG Trom DLG5988S
heatman101
Asker
Jan 03, 2011 | LG DLG5988 Gas Dryer
My Samsung dishwasher model # DMR77LHS makes this terrible grinding noise when it is initially turned on & then 2-3 more times through the cleaning process.
Mine make a grinding noise also when the wash cycle starts. I had a repair guy over fixing my fridge and he said it was the washer motor. My machine has only been in use for 1-2 yrs. Other owners say that the tabs on the top rack break off and get lodged in the machine. hope this helps a little.
Dec 26, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Dryer is making a very loud grinding, scratching, irritating squeal noise while operating. When it is turned off and manually turn drum grinding noise still there. Any suggestions? I have an extended...
heatman101
Nov 22, 2010 | LG DLE8377 Dryer
My LG Dryer is making a grinding noise.......Any help here?? It's 2 yrs old and I paid 1000 for this piece of junk!
Most likely you have bad front or rear rollers. They had many issues with the rollers on these units and they were on a factory backorder for like 2 months! Could also be an issue with your idler pulley. They are not the easiest to work on and the whole drum would have to be removed to check each roller individually to pin point the problem. Hope this helps _MJ_
Aug 17, 2010 | LG DLE5955 Dryer
Did you resolve your dryer / noise?
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Mar 22, 2009 | LG DLE3777 Electric Dryer
LG DLE5977 Electric Dryer Logo
932 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
