Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Broken Glass Hi! A glass bowl shattered into 10,000 pieces inside out dishwasher. We cleaned out what we could but there is glass stuck in the bottom. It seems like a no-brainer not to run it, but I will ask, will it hurt the dishwasher to run it and let the glass drain out? Is there an easy way I can fix it or do we need to bring in an expert?
  • Anonymous Nov 20, 2008
    a glass shattered in my dishwasher and water will not come through, partner has cleaned it all out , and the pump and filter think the pump maybe jammed????
Sorry if you've already tried this (and it doesn't really answer your question)... Have you tried taking a damp paper towel to the bottom of your dishwasher - that trick picks up the really tiny glass particules - or a wet/dry vac?
Posted on Jun 26, 2008
Cleaning the filter on frigidaire ultraquiet dishwasher
Hello Friend,
I see that you are wondering how to clean the filter on your Frigidaire dishwasher, model# FDB1050REC. The inside of your dishwasher is self-cleaning with normal use. If needed, clean around the tub gasket area with a damp cloth.
The filter is self-cleaning. A glass trap located in the center of the filter is designed to collect pieces of broken glass, straws, bones, and pits. To remove this glass trap, grasp the handle, lift out, empty it and replace it. Hope this helps.
-Best Regards-
WP
Feb 14, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
The oven door inside glass has shattered and I was wondering if and how could I replace the inside glass pannel?
Hi.
Yes it is normally possible to replace broken door glass.
Try the following site for some very helpful information
WWW.YOUTUBE.CO.UK
In the search box enter--REPLACING OVEN DOOR GLASS.
Ther are several videos on how to repair oven doors.
Jan 03, 2011 | Ovens
My maytag dishwasher is not cleaning properly. when the cycle is finished i find that the detergent did not disolve and rinse away. Instead I find it in a hard crusted lump on the bottom of the machine....
This means the bottom cleaning arm is not spinning. Most arms are removable, one large nut or some plastic fingers or a release. Remove the arm and clean it out. There is likely food, glass or objects stuck in the arm. Broken glass can be really stuck! Watch your fingers!
Apr 16, 2010 | Maytag 24 in. MDBF550 Built-in Dishwasher
Water doesn't drain out of bottom.
Broken glass is caught in the pump. a take apart cleaning of the pump and drain hose is in order.
Mar 13, 2010 | Maytag MDB9600A Jetclean II Built-in...
Motor just hums during the wash cycle. Put it in
OK, that piece of glass may have jammed the wash impeller. this will destroy the motor windings. you will need to gain access to the circulation motor asap.the impeller is attached to the motor that is housed within the pump casing(upper). try to manually move the impeller. if its stuck, try ot remove the obstruction.
It is possible that, the motor is already damaged to the point of no return. in this case, replace the circulation motor. your drain pump should be ran by a totally separate motor(wax).
**NOTE
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Really bad sound, pump dry or something
hi,
if some shuttered/debris **** inside of the pump it stuck on your impeller balde inside pump,its not easy to open pump assembly,
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.have a nice day rate my solution if your satisfied,thanks
May 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kitchenaid Superba Dishwasher clogged or jammed with broken glass
You will probably have to get at it from the bottom, possibly the back of the washer. Here is a link to your repair manual.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kitchenaid_dishwasher_product_list.html
Feb 02, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Broken glass at bottom of dishwasher
There should be torx screws or 1/4 inch screws holding the filter down to the bottom , you should know when you get there because you cant go any further. good luck.
Dec 30, 2008 | Frigidaire Dishwashers
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
212 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
