Question about Canon PowerShot A520 Digital Camera
Sd is locked and cannot remove pictures from card
  • Anonymous Oct 10, 2008
    same problem here, tried formatting and made sure switch was in unlocked position. This is on a M-40 though
How to removed memory card from my a530 canon
Posted on Dec 25, 2008
On the side of your SD card there should be a little sliding switch. Slide the switch back up and that should solve the problem of the card being locked.
Posted on Dec 02, 2008
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
Tip
How to Unlock SD Card
<p>Many times people do not realize that a <span style="font-weight: bold;">SD card</span> can be <span style="font-weight: bold;">write protected </span>or locked. They will <span style="font-weight: bold;">try to download pictures</span> or <span style="font-weight: bold;">make changes to the pictures </span>and the <span style="font-weight: bold;">SD card will not allow</span> them to do it. The little lock feature on the side of the card will <span style="font-weight: bold;">write protect the SD card</span> so that changes cannot be made. You will need to <span style="font-weight: bold;">unlock the SD card</span> to be able to make the changes that you want to make or download anything from it.<br /> <p><br /> <br /> <p><span style="font-weight: bold;">To allow the SD card to be accessed</span> is a simple as sliding a small tab on the side of the card to the <span style="font-weight: bold;">unlocked position</span>. Usually this means sliding the tab towards the back of the card and away from the front of the card. The card will have to be removed from the <span style="font-weight: bold;">camera</span> or <span style="font-weight: bold;">PC</span> to be able to do this.<br /> <p><br /> <br /> <p>Here is a <span style="font-weight: bold;">picture of an SD Card</span> and you can see the tab on the side of the card. It clearly shows you what is the locked and unlocked positions on the card.<br /> <p><br /> <br /> <p><img src="heatman101_2.jpg" /><br /> <br /> <p><br /> <br /> <p>This feature can be very useful to make sure that you do not inadvertently <span style="font-weight: bold;">erase data or pictures</span> from the card. If you have children viewing pictures on the SD Card make sure to lock it before allowing them to play around to make sure that they <span style="font-weight: bold;">do not erase your pictures</span>.<br /> <p><br /> <br /> <p>As you can see this is a very good feature to have and it will be very useful to you, but you do need to remember to unlock it before trying to make changes to the card.<br />
on Apr 21, 2011 | Cameras
SD memory card is locked. How do I unlock it?
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Jan 20, 2013 | Sony Alpha DSLR-A290L Digital Camera
Memory card locked
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 19, 2012 | Nikon D3000 Digital Camera
I have saved all my pictures on my computer, but now the camera is saying the card is locked and I can not delete them from the SD card to clear it. The lock is not on on the SD card, I don't want to...
try this remove SD card from camera, put it into a SD USB converter, use this on the PC and Format the SD card FAT16, this should remove all data. return SD card to camera, the camera may then want to format the card itself, if so this is all OK.
Also ensure that the little protection switch, on the SD card if there, not all have one, is set correctly... toggle it if there.
Sep 10, 2011 | Pentax Optio M50 Digital Camera
When we try to take a picture on our Vivatar Camera it says,card locked. Please help us with this problem.
Most likely your sd card is locked. Try removing the sd card and moving the small white tab on the side of the sd card from locked to unlocked and give it a try.
Lewis
May 15, 2011 | Vivitar ViviCam 5024 Digital Camera
How do i unlock my memory card its not allowing me to take photos.
I am assuming that your camera uses and SD card to store the pictures.
If you remove the memory card from the camera, you should see a little slider on the side of the card that says "lock," it is easy to accidentally lock SD cards.
I have attached a picture to show you what a locked SD card looks like.\:codyrt.jpg
Here is another image showing the card in the unlocked position: codyrt_0.jpg
Mar 01, 2011 | Cameras
Micro sd card
open your sd card then it the lock slide if damage replace ....
Feb 06, 2009 | Cell Phones
Need help seting up camera
Sd locked means your card is locked so that you cannot delete pictures.remove card & slide locking tab down-the tab is on the edge of the card.hope this helps
Jan 25, 2009 | Moultrie MFH-DGS-100 Digital Camera
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
Canon PowerShot A520 Digital Camera Logo
59 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
