Question about AEG Washing Machines
The armiture is arking at the brushes/ replaced brushes there is a cliking sound/ the coil canectors are discoloured in places do i need to replace the armiture?
    President:
  • 1,462 Answers
Usually you have to replace the whole motor and yes you need to do so.
Posted on Jun 25, 2008
My makita cordless drill barely turns and is smoking
If it's pulling hard then gets hot enough to smoke your problem could be in either the motor or transmission. If you can, seperate the motor from the trans and try running the motor by itself. If it spins free and strong, you have a jammed transmission causing the motor to over heat. If it still labors your problem could be with the armature bearing(s), brushes, or armature windings.
Aug 19, 2012 | Dewalt Makita Bhp452 18v Cordless 1/2"...
Hilti TE14. It rotates slowly and i'm getting a burning smell from the area around the armiture?
I would bet the armature is shot for sure and possibly the field. When an armature shorts out it usually gives off excessive sparking from the brush area. When a field fails it will usually run very slow if at all.
May 17, 2012 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
I have 76 Kawasaki 900, haved replaced ignition 3 times! One side of ignition keeps going out! What could be causing this? Bike is a KZ 900
Try disconnecting all electrical connectors( one at a time) spray them with electrical contact cleaner( not wd40) and brush the residue out with a small stiff brush. This includes the main ignition loom,coil leads,igniter leads,fuse box and regulator.
It is probably a very poor connection and this causes it to fail. When you change it it possibly renewing the electrical contact. The slightest discolouration on any of the connections will cause problems. Good luck. jamesey555
Aug 06, 2011 | kawasaki KZ 1300 A1 Motorcycles
No 1 cylender misfires 1300 rpm
replace your ignition coil.ok
Feb 13, 2010 | 2000 Toyota ECHO
ENGINE RUNS BUT NO POWER TO OUTLETS
When you flash the field, are you going + 12 volts to the top or right side brush? Negative to the other brush? Try three times for 2 seconds?
Sep 25, 2009 | Coleman Powermate Premium Plus 6250W...
No spark
Replace the coil make sure when insalling new one gap between flywheel and armiture .500 mm
Aug 12, 2009 | Tecumseh Garden
Table saw skilsaw model number 3400 15 amp
What you are describing sounds like the power is being interrupted somewhere. In my experience, this is usually casued by a bad switch. Try replacing the trigger switch.
Dan
Oct 19, 2008 | Bosch 7 - 1/4" Skilsaw Circular Saw
Washing Machines Logo
32 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
