Lost power Hello, I have this normally great sounding Deluxe Reverb (1966-ish). It was working perfectly when I last turned it off. I wnt to use it again recently and it has no power. When I turn up the volume it has kind of a compressed sound and no balls. No smoke or symptoms that would indicate a major failure. Could a tube have gone bad? Any thoughts would be helpful. Thanks, Jack RI, USA
  • jackjohn Jun 27, 2008
    Thanks for your advice. I swapped the tubes with a newer deluxe that I have with no change. Still sounds weak and even cranked up to 8. I think I will have to take it to a local tech to try and find the problem. It worked fine one day, then the next it was weak. I can't explain it. I was hoping a tube was the answer. Many thanks!
    Jack
  • 1,512 Answers
Hi jackjohn
It could be a tube, it could be the usual old age catching up with it. I would start with checking the tubes and see that they all light the same way and colour. Also check for white dust in the end of the tube where it is normally silver. Give them all one by one a bit of a wriggle when the unit is going to see that they are all seated properly. It may be a rectifier tube 5R4 gone, replace it out or do some DC voltage checks about the place. remember there are high voltages present!! It A new set of output tubes never go astray in a classic amp like this. Use Electro Harmonix 6V6EH output tubes, gain matched set of course. They work great at higher voltages that these ol girls use. You could of course, just drop it to a Fender repair guy... and he'll be able to sort it out without mucking around. :)
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :)
If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jun 25, 2008
I've told my Frontman 65r has a real reverb tank (accutronics). But it's almost imperceptible, even with the reverb knob at 10. Is that normal? Also, mid scoop for the drive channel and treble/bass for the...
The reverb should be quite strong. I would first look at the reverb volume pot R42 which is a 50K pot. I would also check the voltages on the test points near U4 (TLO-72 op amp tp13 and tp14) which amplifies the signal coming out of the box. It is possible the box has low power levels as well.
The problem is going to be around that section of the board if it isn't a dirty or dead(ish) pot.
The reverb should be noticeable enough to be annoying ;-]
Mar 18, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Sometimes the reverb works, then next day it dont.i have a 1999fender hot rod deluxe
Fender Amplifiers are notorious for their reliability issues.However, I'm sure that amp will sound sweet once you get everything working again!
The problem is likely your "tank". The tank contains the springs which create reverb as the guitar's signal is sent through them. A broken spring could be causing your problem.
Luckily, any of the larger music stores should have them avalible.
Good Luck!
-Sheeves
Mar 02, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My reverb on my Fender deluxe Hot rod amp has stopped working. What is wrong?
Your reverb spring is most likely broken. If it has electronic reverb, then the chip has gone out. For both of these problems, a qualified amplifier technician will have to look at it and replace the parts.
Hope that helps!
Feb 13, 2011 | Fender Hot Rod Deluxe Guitar Combo...
How do i connect the boss gt 10 to a fender blues deluxe amp and bypass the amps preamp
You can plug the output of the gt10 into the "power amp in" jack of the Fender. This bypasses the preamps in the Fender but uses a buffer amps in the Fender to drive the power amp. Please note that the reverb is STILL in the circuit when you do this. You can turn the reverb to zero if you wish to disable it.
Jun 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Amp is little used and now the reverb is not working. It is never moved from the room where I play.
There are only TWO op-amps and the tank involved with the reverb. Both of those are in one IC chip labeled "U2". It is a TL072.
Pin 1 of that chip is the output to the tank and pin 7 is the inout of the reverb control pot that then goes into the power amp.
They resistively mix the delayed reverb signal with the straight signal at the input of the power amp.
I assume you have turned up the reverb control which is just a volume control for the signal going through the tank.
There are so few parts involved with this that a failure is really rare.
May 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fix Reverb unit on Fender Hot-Rod Deluxe Amp
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
Apr 24, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Reverb wont work !!!!!!! Hot rod deville 410
probably a bad reverb tank. there is a little inductor inside that shorts out easily/common. you cant repair it. its just easier to order a new tank. what you do to test is........turn on the amp with the reverb turned up all the way........ volume up on the amp at normal playing level.....then tap or knock on the reverb tank itself......if you get sound then the output of the tank is good/ no sound the ouput side is dead.......then what you do is unplug the ouput of the tank and plug the output wire to the input of the tank and tap/knock on it again....if you get sound then the input side of the tank is good/ no sound is dead. this is a way to test the tank independently from input to output. which side is bad is irrelevant, what is improtant is determining if the tank is toast. i can get accutronics tanks from my distributor at a better price than anywhere else. email me thru my contact page on my website with the tank code numbers and letters so i can get you a price also check my price with whats on ebay, etc. my website is yostamplifier.com
good luck
Feb 07, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Jul 24, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fender reverb mod both channels
Go to http://www.silvertoneamps.com/micKfender/Fender-Reverb-Both-Channels.html
there is info on this mod. heed the warnings of hot rod activities!!
There is a solution to your misguided nods you mentioned earlier.
Dec 16, 2007 | JBL Control 23 Speaker
 Grubhead
Grubhead
