Question about Mitsubishi Televison & Video
Repairs to HD1080 TELEVISION
POWER BUTTON DOES NOT REMAIN ON FOR OVER 5 SECONDS
  • kavita chankadyal Jun 25, 2008
    when power is turned on ,it goes off after 5 seconds. there is neither sound nor any picture on the screen
    Guru:
  • 859 Answers
The reason the power light goes off after five seconds is because the power system is not energizing, You are getting power to it or there would be no light.
There are user replaceable fuses in most case and not in others. If you are going to remove the back of your set you need to adhere to these safety measures.
1.) Power is stored in high capacity capacitors that can contain up to 4,000 volts. Should you touch these you will get severely shocked and have a nasty burn to deal with.
2.) Do unplug your unit and do not do this without shoes on more specifically sneakers.
3.) Have someone with you in case you are electrocuted who can call 911 and provide cardiac resuscitation if you need it.
Have a plastic flashlight on hand to look at the area of the set immediately around the main power transformer where the cord comes in. Look for the easily recognized inline fuses you'd expect to find. Depending on your set you don't have any or you may have several. Give those a good look until you are certain the internal wire is present or burned in half near the center. Should any be blown carefully remove them by lifting one end up with a small screwdriver and then use a pair of pliers to gently withdraw the fuse completely. Do not do this barehanded. There are rating markings on the silver colored ends of the fuses giving amperage ratings and replace these fuses with an identical rated fuse.
If you do not find any blown fuses that doesn't mean all hope is lost you just won't be able to service it yourself. Have a qualified service technician come in and service the set if its worth it to you.
Regards,
Worldvet
Posted on Jun 25, 2008
    Brigadier General:
  • 6,966 Answers
The only easy user option I can forward is to try a full hard reset. Though it may sound much, it is actually nothing more than simply unplugging the Mitsubishi from the mains for a couple of hours (preferably overnight). The idea is to revert most (if not all) settings back to factory default.
If you can likewise hear a clicking sound coming from the rear, then that would mean the auto-protection is kicking in and is keeping most of the internal circuitry from powering up to prevent further damage, Having said this, then it would mean that it is no software glitch and there is a hardware fault. Often problems would involve power supply circuitry (a blown capacitor is most likely) together with other components such as pico fuses, resistors, regulators to name a few.
At this point your best bet may be to seek the services of a qualified personnel. Should you venture to perform a DIY, pls be reminded that diagnosis/repairs would call for familiarity with electronic circuitry and components, use of a DVM and a soldering iron and access to a service manual or at the very least a schematic diagram with voltage settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 1,011 Answers
Dear Sir,
Let's hope it is just a corruption of the software codes in the power management circuits of the TV.
Do a hard reset and see if that will bring it back to life.
HARD RESET: Merely unplug the power cord for 4 hours. Then power it back up again.
If this does not solve the problem it means there are other problems. So, let me know the outcome.
Good Luck
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} “Don’t Forget to rate the Solution”
  • 2,071 Answers
Power on and it goes off after 5 seconds ,,the system is automaticaly shut off the unit this is of two causes cold solder or crack of the joint in the power supply section ,and to the horizontal section .and the other one is shorted Horizontal Output Transistor, If HOT is shorted the unit power on and goes off like yours.HOT produce the high voltage that we can the see picture. Automatically shut off the system because shorted HOT,and trap the voltage of power supply..only you do is to change the transistor in the horizontal section ..so your tv will works again.this is not cost too much...
  • LORETO LACARON
    LORETO LACARON Jun 25, 2008
    You better find a technician to do repair for you, to avoid high voltage shock. only to change the transistor and little reheating...
  • LORETO LACARON
    fuses are nothing to do this problem because of the indication of power automatically shut off. if fuse are blown you cant turn on the unit... this unit is turn on then shut off..
    Sergeant:
  • 243 Answers
It is a power issue, you will need to have the tv serviced. If you need their contact info just let me know.
Thanks,
lee
  • 796 Answers
Check down the thermal fuse...
only that object can turn off the tv by its own..
  • 3,037 Answers
So you press the power button, the whole tv turns on and then 5 seconds later everything turns off, correct? If not, please explain with more detail. Also does the power button flash at all. Do you have audio and video for the 5 seconds. Please let me know so I can narrow down this problem
  • Benjamin Patri
    Benjamin Patri Jun 25, 2008
    Does the power button start to blink or change colors?
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Hd1080 power wont com on green lite that says timer blinks wen u plug it in but wont turn on
Thats usually caused by failed capacitors on the DM power board. REplaceing them will usually fix the issue. You can get the DM repair kit for your model at www.tvrepairworld.com which contains the upgraded caps and the CD with repair instructions.
Apr 29, 2011 | Mitsubishi WS-55809 55" Rear Projection...
My recorder show HOLD how to clear hold
Hello
Reset the unit to its factory settings by the following methods.
Press and hold CH Up and CH Down button on the main unit for about 5 seconds.
(Current channel line-up and television program list are cleared.)
Select "Yes" in "Restore Default Settings" in the SETUP menu.
This returns all values in the SETUP menus, except for the clock, channel settings, ratings
level, and on-screen language, to the default settings.
While the disc tray is open, press [DVD] then press and hold REC button and Play/ [PLAY/* 1.3] BUTTON on the main unit at the same time for 5 or more seconds
Press and hold POWER button on the main unit for 10 seconds. (The settings remain.)
OK.
Mar 24, 2011 | Panasonic DMR-EH60 DVD Recorder/HDD...
Color recently changed and I cannot get it adjusted properly. Picture goes in and out.
Please do the following steps:
  1. Turn on the television.
  2. Please wait approximately 40 seconds for your TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button.
  4. While holding the UP ARROW button, press and release the POWER button on the TV set. (The button may be on the front, top or side of the TV.) NOTE: The TV may turn off and then back on.
  5. Release the UP ARROW button.
If the issue does not resolve, please follow these steps:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Feb 27, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I lost the codes for my reomote control i need to program my remote to my television
Hi! Try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER/SAVE button. The INDICATOR LIGHT will go off.
try searching for your codes by following the steps below.
I hope this helps.
Oct 12, 2010 | Universal Remote Control GE174Universal...
How can i re program my Ge REMOTE CONTROLER to my philips magnavox television without any codes?
Dec 13, 2009 | GE JASRM24912 Remote Control
When I press the power button, caps lock, scroll lock, num lock, power led and hard disk led blink in every 5 seconds
they continue to blink every 5 seconds until you turn it off? It should blink all lights upon powering on but then remain off,
Aug 13, 2009 | Dell Latitude C600 Lcd LCD Display
2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
Jun 03, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Locked TV
Good day, Katie0113; I hope you solved this concern by now but if not here is the fix: To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. I hope this helped, good luck, big IRISH.
May 19, 2008 | Mitsubishi VS-50609 50" Rear Projection...
TV Zoom mode
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
May 16, 2008 | Sony KV-32FS13 TV
Televison & Video Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
