Using an Ibico Pouchman 12. Using an A3 laminator pouch, and it has got stuck in the machine. and is not coming out the other side. How do i fix this?
4 Suggested Answers
  • 199 Answers
SOURCE: Laminator
ok we think again
Posted on Jun 22, 2009
goodgold
  • 389 Answers
SOURCE: laminating gbc h212 heat/time/material/seal coming undone
It/s work for service. i see mekhanik trouble
Posted on Mar 14, 2010
SOURCE: My office has an Ibico
I need a new cord. Also, the machine does not get hot enough to melt the holes.
Posted on Jun 22, 2011
How do I get something out of that the laminator ate?
You can't do any more laminating until you do. Some laminators have to be used with a document carrier and some don't. It sounds like yours does need one. This happened to me once. You have to remove the screws on the bottom, lift off the top and you will find your document and laminate pouch wrapped around the roller. Using a sharp paring knife or nail scissors, cut the pouch along one side making sure not to damage the ceramic roller. I have a recollection that I cut the pouch away on both sides. I used a chef's boning knife as this was at work in an airport business class lounge.
Oct 12, 2016 | Apache Al18p 18 Professional Laminator
Reassemble after having to take apart?
did you get it fixed, I had the same problem but with a different part , I know where your part go's
1st without screw holes go's in the Rear where the laminate comes out and the next one goes on top email me if you didnt fix it yet , I can open mine and get pictures Email me here
scolt@tampabay.rr.com Subject Laminator APL-330U
Oct 22, 2014 | Royal Sovereign 13" APL-330U Hot & Cold...
Pouch stuck in laminator
Firstly switch off the laminating machine and plug out. Turning off the machine will prevent the motor from burning out. As the motor is not burnt, there is no need to repair or substitute the machine.
* When the machine gets turn off look for the damage instantly, if any. If any huge item was inserted to laminate, it might have happened that the item had stuck in the machine. First of all, try to pull out the item gently from the machine. Also, remember that thick and three dimensional items should not be laminated in the laminating machine.
Hotmail Support ' Aol Support
Apr 09, 2013 | Office Equipment & Supplies
Can I use A4 and A3 pouches in my laminator?
No the machine is made or trained to use the pouches it ask for.
Jan 30, 2013 | Office Equipment & Supplies
Some one at work tried to laminate a card. when it did not come out she put in another sleeve thinking it would push the other out. smart uh! how do we get the 2 pages out?
If you were using GBC brand laminating pouches they don't need a carrier, if you were using another brand of laminating pouches, then a carrier is needed (something they don't clearly specify) and that's why the laminating pouch got stuck.
If you have had the laminator under a year, it should be under warranty, and you can call the company, and they will send a replacement, and they will probably then inform you of the above listed laminating pouch issue.
You may also want to try using the reverse button, but many times the pouches will get stuck between several rollers, and you risk destruction of the entire machine by attempting to take them out manually.
May 31, 2011 | Gbc HeatSeal H425 Laminator
Have a used Fellowes EXL a4 laminator. Need a manual or instructions for use. Thanks.
Set- up
The only assembly required for an @Home laminator is attaching the wire support rack, which ensures that the sheets coming out of the machine cool in a flat position and do not curl. Using the illustration on the inside of the manual cover as a reference, push the ends of the rack " into the holes ! in the back of the machine as far as they will go.
Operation
Your laminator works by means of two rollers, one on top of the other, each turning in the opposite direction to draw a plastic, open-sided pouch coated with adhesives through them and out of the machine. Understanding this simple mechanism will help you decide what materials you can laminate without risk of damage to your machine. You can feel confident laminating all materials that are flat and dry, for example, but should avoid those that:
• Contain liquids, gels, or even moisture, that could escape
• May crumble or otherwise disperse under pressure, or
• Are likely to break, as could glass or rigid metals and plastics.
With hot lamination, where the rollers are also heated, make sure you don't put anything into the pouch that could melt and leak into the machine.
Once you have checked the suitability of your contents, you need to decide whether to use cold or hot lamination. Cold lamination, also called self-adhesive lamination, bonds materials between an adhesive and a non-adhesive sheet solely by means of pressure. As a result, this method tends not to produce as tight a seal against water and the elements as
hot lamination, but can be useful for heat-sensitive materials, such as thermal paper or fragile documents. While the cold method used to be the only good way to laminate photographs, today's heated-roller technology enables you to achieve excellent results and is therefore probably the better choice.
5
The contents and the mode decided, the next step is to choose the right pouch for the job.
Hot and cold laminating pouches are especially designed for their separate purposes and cannot be substituted for one another. When it comes to pouch size and thickness, you should make sure that the one you buy is no wider than the entry # of your model and not thicker, together with the contents, than the capacity of your machine. If you are laminating paper of a standard size and weight, you can quickly see your pouch thickness options on
the selection guide stored under the machine:
• White and gray boxes indicate that the pouch/paper combination can be used
• No box on the table indicates that there is no combination possible with your machine.
If you find several pouch options for your document, take the one that best suits the purpose:
The thicker the pouch, the more rigid and resistant the laminated sheet will be. If you are not sure of the paper's weight or are laminating other materials, the combined thickness of the pouch and contents should be your guide. The maximum in this case is the equivalent of a stack of 6 to 7 sheets of standard office paper. (See Product Profile for details on capacity limits.)
If even the smallest size pouch will leave a lot of space around your contents or you want the lamination to conform to the shape of your contents, wait to cut it to size until after lamination: a laminating pouch is precision-cut to ensure minimal leakage of adhesives, and this cannot be replicated with scissors or a paper-cutter. You'll also find the pouch easier to cut when it is hardened.
How you arrange your contents in the selected pouch is important in both cold and hot modes. To produce professional-looking results and ensure a long working life for your machine, follow these simple guidelines (see illustration on the inside of the manual cover):
1. Lay contents as close as possible to the sealed edge of the pouch, which is the end you will be feeding into the machine. If the material is more than 1 cm or 1/2 inch from this edge, the rollers will not have enough traction to draw in the pouch and will turn continuously without advancing it.
2. Arrange multiple items close to each other in the pouch, with the edges no farther than 1 cm or 1/2 inch apart. If there is a larger gap between items, the rollers will slip into it and lose their traction. As above, the rollers will turn without advancing the pouch.
3. Leave a free margin around contents of at least 3 mm, or 1/8 inch, on the three unsealed sides of the pouch to guarantee a strong seal. This is a minimum, meaning you can have as much margin beyond this as you wish.
To begin laminating, place your machine on a work surface where you have enough room at the back to allow the full length of the pouch to clear the material exit '. Plug in the machine and press the power button &, which will start the rollers turning. If you plan to do laminate both cold and hot in one session, it makes sense to start with cold, so you don't have to wait for the machine to cool down. (This can take one to two hours.)
In either case, to save energy and reduce wear-and-tear on your machine, turn off the machine as soon as you are finished by pressing the power button &. If you forget, however, the machine has an automatic switch-off function, which causes it to turn itself off one hour after not being used.Cold Lamination
With the contents and the pouch you have selected at hand:
1. Turn temperature selector $ to . The machine will indicate its readiness by turning on
the green standby light % and giving an audible signal.
If the machine is at room temperature, this will be almost immediate.
2. Place contents in pouch in line with the guidelines (p. 5). Lay the pouch on a flat surfaceand open it so that the adhesive side, which is covered by a glossy protective sheet, is vertical.Place the contents face up onto the transparent, non-adhesive side, but do not closethe pouch.
3. Insert sealed edge of the open pouch into the entry, as
shown, bending the protective sheet backwards over the
machine and grasping its free edge. As the machine draws
in the pouch, keep holding on to the protector, which will be
peeled away from the adhesive side as the pouch moves
through. Although it is easier to take off the protector and
close the pouch before you feed it in, you will create air bubbles
and other irregularities that the machine will not be able
to even out.
The finished sheet will emerge from the material exit ' by itself. Remove it from the support
rack only after it has completely cleared the exit.
Hot lamination
1. Turn temperature selector $ to or . The boxes in the selection guide you used to
choose the pouch size and thickness also indicate what temperature setting you should use
with your pouch:
• If the box is white, use ,
• If the box is gray, use .
If you are not sure of the weight or thickness of the contents or pouch, you will avoid possible
damage if you start with the lower temperature. With the lower setting, the machine will take 5 minutes to warm up and with the higher, one minute longer. When the laminator has reached the setting you chose, it will indicate its readiness with a green standby light % and an audible signal.
Unlike with cold laminating, the contents can be face down or up within the pouch. Close the pouch once the contents are arranged.
3. Insert sealed edge of the closed pouch into the entry #,
as shown, and release it as soon as the machine begins
to drawn it in, as shown in the illustration.
itself. Remove it from the support rack only after it has completely cleared the exit.
7
Maintenance
To keep your laminator free of adhesives that could hurt the quality of your work, you should clean the rollers from time to time, or frequently, depending on how often you use the machine. The best way is to do this right after you have finished hot laminating, because the rollers will still be hot, which is necessary for the cleaning process.
To clean the rollers:
• Turn selector to if it is not already on this setting
• Wait for the readiness light and signal
• Insert the cleaning sheet included in the package, repeating one or two times
• Insert a plain white sheet of paper to test for remaining traces, and
• Reinsert the cleaning sheet, if necessary, and retest.
To clean the exterior of your machine, just wipe with a soft cloth dampened with plain water.
Dec 15, 2010 | Office Equipment & Supplies
Using a DWL-4A laminator I followed the directions my paper went in, and nothing came out the other side it must be stuck but the laminator dosent open how do I fix this?
You're lucky. My pouch won't even go in! Poor quality product and as I've had it in the box for so long before trying it, I can't even send it back!
Dec 11, 2010 | Computers & Internet
I have a Ibico el12 ii laminator and need to know how to use it. I cant find the instruction manual for it at my new job i put the sheets in as it shows but it labinates the first 1/2 inch then goes no...
You need to put your document in a carrier to prevent the heat from buckling the pouch before it makes it into the rollers. I've had a similar problem in the past before I remembered to use the carrier.
Jul 02, 2009 | Office Equipment & Supplies
975 people viewed this question
jasbo
jasbo
