Question about Singer 7462 Mechanical Sewing Machine
I am having trouble threading my singer industrial sewing machine I can't remember how
  • 323 Answers
All machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.Your Industrial machine has a long groove on one side of the needle. This long groove must be on the left side of the needle when it is inserted properly.
sewman7
Posted on Jun 25, 2008
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
Threading instructions
There are manuals for several of the submodels of the Singer 81 class here: http://parts.singerco.com/IPinstManuals/
Apr 25, 2014 | Singer Sewing Machines
Manual for singer 195KI industrial plain machine
How do you thread up and wind thread onto a industrial singer sewing machine model 195KI
Feb 05, 2013 | Sewing Machines
How to thread Consew Industrial Sewing Machine 206RB
Every machine is a little different, but the basics are the same. Our 7th grade Home Eco. teacher taught us the first day...
"...Start at the thread spool, thread guide, thread guide, tension, take up lever, thread guide, thread guide, needle. Learn this and you can thread any sewing machine"
she was right, As this hold true for my kenmore, juki, singer and new home machines. Same basics for industrial machines too.
Hope this helps.
Sep 16, 2012 | Consew 206RB5 Sewing Machine
I inherited an old straight stitch singer sewing machine
If you send me a picture of the machine I can tell you what the model is. Is it an industrial or domestic machine, it sounds like it may be an industrial ?
sewingmachines@gmail.com
Oct 09, 2009 | Sewing Machines
Thread breaking during sewing on Ericco sewing machine
replace the needle, use a heavier thread, insure the material is advancing properly as you sew.
Feb 08, 2009 | Singer Sewing Machines
Industrial over locker
The singer site would be a good place to start. There are also groups on Facebook that you can ask a lot of questions about industrial machines.
Oct 02, 2017 | Sewing Machines
Singer 7462 Mechanical Sewing Machine Logo
121 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
