Question about Texas Instruments TI-83 Plus Calculator
TI-83 plus calcutor I need instruction manual
I lost my instruction manual for my TI-83 Plus calculator. I'm getting ready to start back to college and i need one bad so i can learn how to use it.
  • knafree Jun 30, 2008
    Need directions for my TI-83 Plus I have lost them and need them for college
  • Anonymous Jul 01, 2008
    Where can I download the instruction manual for the TI-83 Plus? It is my son's and now I need it for school and don't know how to use it. Thanks.
Could you please download the TI-83 Plus instructions to so I can understand what to do on the calculator.
Posted on Jun 25, 2008
I haven't used the calculator in a long time(TI 83 plus) and I put in a new set of batteries. The old ones that were in left some battery acid, but not much. The calculator doesn't want to turn on. It's a...
hi adamsukienni,
Clean the battery damage up real good. Gently scrape to terminals of corrosion. Back in my day we use to put a little bit of coke cola to clean car battery posts to get a good connection. If you could put a little bit of coke on a Q-tip without getting any inside the calculator that would be good. Just let it soak in for about 30 minutes. And gently scrape the bad areas again clean of the corrosion. You have to clean it up to metal so, that when the battery is in it will be metal to metal connection.
If you can download new OS with another Ti83 Plus or, don't want to install the new OS goto Procedure 1.
Be ready to install the new ti 83 OS v.1.19. So, setup your computer with Ti Connect software and, have the new OS v.1.19 download ready and, in "My Documents \ My TI Data \ Downloads." If you need additional instructions on how to connect the computer to the calculator you can read my instructions at another posting I did. You can go to that posting by clicking, "Connection Instructions," under this paragraph. Just remember the OS was for a Ti 84 Plus and, your's is a Ti 83 Plus so, don't download the OS from the other posting. I'll give you a link below this paragraph to download the correct Ti 83 Plus OS v1.19 for your calculator here at your posting. Just follow the other posting to where I say, "You can also go back and, download the Ti 84 Plus guidebook too, if needed." After that statement the computer and, calculator get connected with the cable and, your not ready for that process, yet! When you come back to this posting and you have downloaded the new OS to the proper folder goto Procedure 1.
Additional computer to calculator connection instructions click, "Connection Instructions."
Ti 83 Plus OS v.1.19 download click, "Ti 83 Plus OS v.1.19". Save this download to "My Documents \ My TI Data \ Downloads".
Procedure 1.
Take all the batteries out for 10 minutes, including the very small one that you have to use a small philips screw driver to get it out. Watch out for the spring under the small battery, it might pop out. Replace all the batteries after 10 minutes with new ones, including buying a new small battery. The small one might cost about $5. I know it is expensive but, this might work.
A battery reset procedure should bring your Ti 83 Plus back to life.
Make sure the batteries are in correctly? The batteries alternate negative/positive, positive/ negative and so on. The first time I put the batteries in, I didn't have them in correctly. I know if it happen to me that anybody could make the same mistake. And of course, the calculator will never come on if the batteries aren't in correctly.
If your Ti 83 Plus turns on when you put the batteries back in you do not have to re-install the OS. I just think it is better since, your OS might be corrupt.
The process below should reset your calculator.
1). Pressing the [2nd] key followed by pressing and releasing the [Up Arrow] key. This adjust the contrast in case the contrast was to low. Keep repeating if necessary for about 10 seconds and, then go to the next step. If calculator comes on and responds to key functions your done. Once again, if your calculator turns on after this procedure you do not have to re-install the new OS. You can quit these procedures now with a perfectly good calculator.
Please be prepared to re-install the calculator's OS, if you run through this process.
2). Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". Connect to other Ti 83 Plus and, install OS from that calculator. Or, follow the instructions, I gave at the other posting "Connection Instructions" to reinstall the calculator operating system and, connect the computer and, calculator. You can start where, I say, "Link your computer and, Ti 84 Plus (Your's is a Ti 83 Plus) with the proper cable (USB or Black Link). Upon completion your Ti 83 Plus will be ready to use and, the new OS installed.
Jan 18, 2011 | Texas Instruments TI-83 Plus Calculator
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
How do i get a manual for TI-83 plus calculator
You can download the Ti 83 Plus Guidebook (aka. manual) right here at Fixya! To download the Ti 83 Plus Guidebook from Fixya! Simply, left mouse click this highlighted link, "Ti 83 Plus Guidebook from Fixya". Once your at this Fixya link, stroll down just a little bit until you will see the word, "Manuals" right next to the green highlighted, "Problems and Solutions". One left mouse click, "Manuals" and the screen will stroll down. Now you will see where you can "Upload a Manual" and, just a little bit further down you can "Download". Just left mouse click, "Download" and, the manual will start downloading to you. You may or, may not have to enter a 6 digit number to begin downloading but afterward, the manual will download in a PDF format.
You can also get the latest version of the Ti83 Plus Guidebook (aka. manual), by going to the Texas Instruments web site. You can get to the Texas Instruments link by clicking this link, "Ti 83 plus manual". Once your at the Ti site left mouse click the Download item, Ti83 Plus/ Ti83 Plus Silver Edition Guidebook (English). Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click "continue as guest" the Ti 83 Plus Guidebook will download to you in a PDF format.
You can also get a hard copy of the Ti 83 Plus Guidebook (aka. manual) at and, many other retailers on the internet.
Jan 02, 2011 | Texas Instruments TI-83 Plus Calculator
I need a manual for the ti 93 plus.
The Ti93 Plus does not exist. There are however a Ti92Plus and a TI83Plus. The manual for either of them can be downloaded from this page.
Apr 07, 2010 | Texas Instruments TI-83 Plus Calculator
Screen obstruction TI-83 Plus Graphing Calculator
The liquid crystal is damaged. I suppose the screen can be replaced. Check with Texas Instruments resellers (usually academic bookstores): they may be able to tell you where you can have the calculator serviced.
You can post an ad on the college bulletin board
TI83Plus Wanted
OK for batteries to be dead
But calculator must be alive.
Hope it helps.
Jun 28, 2009 | Texas Instruments TI-83 Plus Calculator
Lost programs!!!!
I am sorry, but no, there is no other way.
May 14, 2009 | Texas Instruments TI-83 Plus Silver...
Instructions And Usage Of TI-83 Plus Calculator
Mar 11, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 instructions
Download a PDF copy from Texas Instruments:
Nov 29, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
288 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
