Question about GPS
My tomtom 510 was working fine until this morning when I set it in it's windshield dock. The green light to show that it's charging came on but nothing else. It's been on the charger all day but won't come to life. The screen stays black on or off the dock when i hold the on/off button and my home computer doesn't recognize that it's plugged in. Any help would be appreciated
  • Kurt Schultz Jun 26, 2008
    reset button solved the problem. It's small and hard to find but it's next to the docking connectors. paper clip insert.
Remove the docking foot from the unit and expose the docking connectors. The reset button is at the bottom left of the body next to the connectors. It's hard to see but a paper clip will do the trick. Push just hard enough to here it click. Now it is reset.
Posted on Dec 04, 2008
Tomtom 510 - packed up
try re setting the TomTom, reset button is founded on the bottom underneath where the docking mount connect, hold down for 15 seconds, then press the little button on the top on the right side while turning on. worked for me
Jun 06, 2010 | Tomtom GO 510 GPS Receiver
My go 510 is about 1 year old and it was working
try resetbutton, go tomtom.com, sel support, search reset, sel softreset sel device, do as told. goodluck
Feb 13, 2010 | Tomtom GO 510 GPS Receiver
I lost the dock that connects to the computer
Your only option is to purchase another Home dock for your TomTom GO 510. The 510, 710, and 910 all use the same dock. The cheapest place to purchase a home dock is ebay. The answer to the second part of your question is no, you cannot purchase a usb cable to connect your TomTom GO 710 to your pc. The TomTom GO series uses a proprietary dock.
Jul 16, 2009 | Tomtom GO 510 Car GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
My Tomtom 910 is having charging issues.
Hi Evan,
The rubber bungs often come out but it doesnt usually effect the charging although the rubber bung is there to help reduce vibration when used with a mount in a car. I have had many 910's here in the past with the bungs missing but never had any problem with them latching into the mount. I would think your problem is either some other plastic part is worn or broken. However , if you feel that the problem is the bung then I would go with your instinct but you might have to find something else to fit in the hole as parts are not readly available for TomToms unless you buy a whole unit thats faulty to use as parts / spares. Im'e sure something could be made to fit possibly part of an eraser or similar rubber part. You might also be able to use a small rubber cable grommet or similar.
As far as I know , it isnt possible to get a virus on to the TomTom as such but it is possible to get corrupted data on the hard drive ( or SD card with other models ) especially if you download things such as voices etc. I have had TomToms here were owner has downloaded comic voices and the files have caused very strange things to happen with the TomTom. I even had one where a voice file was making it look like the screen was damaged , so , your'e correct in thinking that way. In your case though , I doubt if the dowloaded voices have effected the charging , its more likely the poorly fitting mount thats casuing your problems.
If you manage to get the green light on ( this only shows power is going to the TomTom , it does NOT confirm charging ) then leave it for a few hourse before attempting to turn the TomTom on as that will ensure a resonable amount of charge especially if you battery is very flat.
Hope this helps . ( please rate the above reply if you think its helpful in any way )
Good Luck
Sep 20, 2008 | Tomtom GO 910
My tomtom doesnt turns on. It shows the green led when pressing the power button, but doesnt show anything. It doesnt charge and doesnt show any led while on charge. I tried the reset for 10 sec (and 15...
Remove the micro sd card from your TomTom. Look at the bottom of your unit, where the copper contacts are (where the unit mounts to the windshield mount). You will notice a "cut-out" in the plastic case, just above the contacts. The reset button is there. Use a paper clip and depress this button for 15 seconds. Now press the power button, and it should turn on. Now replace the sd card.
Jun 27, 2008 | Tomtom GO 510 GPS Receiver
TOMTOM GO 710
Could be a loose contact at the connection between the wire and at the gps unit.
Think the green light must be on at the charger port and also on the gps unit.
This green light can be found near the power button on the gps unit.
Nov 22, 2007 | Tomtom GO 700 GPS Receiver
Will not take a charge
I have just the same problem. Initially the battery was flashing to say that it was low on charge even when it was plugged in, then it flashed that the battery was empty and switched itself off. When plugged in the green light comes on, but still cannot turn TomTom 710 on. Also it will not connect to the computer.
Nov 14, 2007 | Tomtom GO 510 GPS Receiver
Will not charge
I have a similar problem and I think I solved it (orr found a way to work around it). It looks like the contacts are not connecting firmly so even though the green light may be on, the charging conneciton is not made. With the tomtom on your home dock from the front page on your tomtom, touch near the lower right of the screen on the satellite strength indicator, this should bring up a screen where it shows (among other things) your batter status at the top right. If it is charging, the word charging will be under the battery strength indicator. Just play with it until you get the word "charging" to appear under the picture of the battery.then HANDS OFF until it is charged. I doubt this will be successful with the car charger since the movement of the car will likely jar the connection loose. Good luck.
Oct 03, 2007 | Tomtom GO 510 GPS Receiver
TOMTOM 510 not reading SD card
I did find out how to solve the problem. I can't remember exactly where I found the solution but I think it was on TOMTOM website. You have to connect to TOMTOM home and reinstall the application. I put the TOMTOM disc in the computer (which came with purchase) and reinstalled the program. Which I thought was weird as everything appeard to be fine with TOMTOM home). Anyway, it worked. Good luck.
Sep 30, 2007 | Tomtom GO 510 GPS Receiver
GPS Logo
61 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
