Question about Sharp R-1505 Microwave Oven
On button is broken
The on button is broken off on hte back side of the control panel. the motherboard is new.
  • Anonymous May 02, 2009
    Display is out and start button inoperable.
My husband took the cover off and positioned the broken button where it will still push on the left corner. I dont know if we can buy just the button or what.
Posted on Jun 30, 2008
Oven Control Panel "OFF" or ignitor is broken?
need model number and brand name,i've seen the power go out and when the power comes back on the power surge takes out the computer board or clock assy.but if she touched the panel she might have locked the board,on some models if you hold the clockbutton in for 5 seconds,some you hold the start button for 3 to 5 seconds or it has a lock button on it so if you send the model number i can check that for you,you can try unplugging it for like 15 minutes and see if that resets it or the power surge took out the board if it's not locked out
Mar 10, 2014 | Microwave Ovens
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a MG208 Combination Microwave Oven and Grill. I got it from Tesco about a year ago. Yesterday I was cooking something in it for 10 minutes but when the clock reached zero it wouldn't turn off. I...
Please go online and type in your make and model, and begin searching for a dealer or manufacturer's web site.
It appears your controller or the control panel is broken, and you should be needing a new control or control panel.
You will need to not use it again until it is fixed, because of danger of fire.
God bless your efforts.
Jul 11, 2017 | Microwave Ovens
Start button not working
We had this problem and a repairman came and replaced the entire control/display panel. Still had the problem some time after he left. I found that there are several ribbon cables in the back that plug in to the circuit board in the back of the control/display panel. There is a wide ribbon that is close to right rear burner control button, (but on the back side). The connector for this ribbon cable is the trouble. If you unsnap the connector by gently pulling out on it, it will release the ribbon cable - which you then pull out and push back in. Snap the connector back and you might be good to go for awhile. At some point, it will do it again. So, I've loosened the back sheet metal so I can reach over the back - without having to pull the oven away from the wall. I feel, with my finger tips, the wide ribbon cable, (roughly behind the right rear burner button), and press on the right side of the connector after setting the temperature. This, temporarily, enables the Start button. This works for only one time. To make it work for about a month, you have to unsnap, pull out and push back in as described above. I'll do this again when I get tired of my wife calling me to the kitchen to start the oven.
I assume the new parts will have the same problem as the original.
What a pity.
Dec 29, 2009 | LG Microwave Ovens
Door open button is broken, door will not open
door button mechanism is all behind the control panel.
there should be a couple screws holding the control panel on, you can see them when you open the door i believe.
you probably need to slide it one way or another to get it to unhook from its hidden catches..
there is the outer button you press with your hand thats available in 3 colors depending on your model #, and then the inner latch..
it will need to be checked to verify which parts are broken..
hope this helps,
best of luck,
ttfn
Oct 18, 2009 | Whirlpool MT4155SP Microwave Oven
Unable to open the microwave door since this morning. the oven still works but its closed. when press at the bottom right side corner, the door supposed to be open.
More than likely, the little lever behind the button has broken. You may notice there is less resistance when pushing the button, but perhaps not if your model has a spring behind the button as well. If your handy, you could remove the front panel and take a look at it, but if you dont feel comfortable doing this, it may be equally as expensive to repair this as it would be to buy a brand new one. I'm assuming its out of warranty at this point, but if not, send it back!
Sep 11, 2009 | GE Microwave Ovens
Can anyone get a hold of the Jenn-Air Microwave M170W Button to open the door (Part# 56001009)Mine cracked and the part has been discontinued. Thank you.
Same thing happened to me. I couldn't find a replacement part, but I was able to make a fairly easy functional repair. If you take off the microwave cover, you can reach the back side of the control panel where the door release button is located. With a screwdriver or your finger, you press down on the top attachment tab (it's the swivel point that holds the button in place) with just enough pressure to remove the button. You'll have to do something similar to remove the other half of the broken button. If the two pieces of the button fit neatly together, then you can epoxy a piece of flat metal or rigid plastic to the back side of the button in order to join the two halves. Be sure to clamp the two halves of the button tightly together while the adhesive sets to get a tight fit and minimize the crack line. Let it cure, then replace in the microwave. It's not cosmetically perfect because there is still a hairline crack in the button, but it's not that visible and the button works well. I can't say yet how long this repair will hold up yet. I suppose that will depend on the quality of the bond you achieve when repairing the button. Good luck.
Jun 23, 2009 | Jenn-Air M170 Microwave Oven
Fan and light buttons pushed in, how do i install new buttons.
I just fixed mine. Same problem.
  1. remove the top vent (like replacing filter) w/ 2 or 3 screws on the top of the unit
  2. Remove the one screw on the top of the clock/control unit.
  3. Remove the clock/control panel by sliding up then out
  4. See circuit board at the bottom for the 3 switches. Hopefully it just popped out of place.
  5. pop it back into place and re-assemble
  6. if it's broken, you'll have to find the replacement part here: http://www.geappliances.com/service_and_support/
  7. If the actual buttons (black plastic) are broken, you have to replace the whole plastic housing for the electronics. Probably a big project and/or you'd replace the whole bit for hundreds of dollars, but even still, it's a pop-out, pop-in.
Good luck,
-tj
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Door
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
If you reply back to this with your brand and model number, we can steer you toward a part source, and possibly toward exploded view diagrams, etc.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Panasonic NN-H275 Microwave Oven
Microwave touch panel is unhinged at the bottom
The mounting tabs on the control panel frame have cracked off most likely due to age, heat, or imperfections in the plastic.
If the tape idea doesn't appeal to you (*grin*) it will need a new control panel frame. That normally comes with a new keypad, but I would need the model number to be sure.
It is probably going to be referred to as the control panel in the parts list and it should run about $50 plus shipping.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Also, these units have mini-manuals hidden behind the control panel and they're very handy to use.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Normally you would unplug the oven from the wall, remove the 2 or 3 screws holding the grille in place, remove the screw at the top of the control panel frame, then CAREFULLY lift up and out to remove it.
Then you can mark and/or photograph the wires to be sure they all get back in the same place. Then you can see how the circuit board would come out and then go into the new control panel frame.
If you don't want to replace it, I would suggest that you get it squeaky clean and dry and use a small amount of household cement or Elmer's Glue-All (not super glue) on just the bottom edge, then temporarily use tape to hold it firmly in place until it has cured and dried.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Microwave Ovens
Microwave Ovens Logo
149 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
