Question about Rockford Fosgate Punch 301S Car Audio Amplifier
Will not power
The thing is there is no fuses on the amp. everything is getting power but its not turning on. i have it hooked up in my truck. i might have just fried it. i dont know
  • 109 Answers
Yeah my guess without seeing it is that you did fry your amp. You really need to hook up two fuses inline on your power feed; one no farther than 18" from you battery and one inline at you amp.
Posted on Aug 19, 2008
Tried hooking subs and amp to my factory deck in my 2006 chrysler town &country limited.. Everything was working but wife's friend started while I was wiring smelled like burning electrical.. Now no s
Only fuse you need is the power wire leading to your aftermarket amplifier for te subwoofer. Which most likely you have too small of a gauge of wire and burned straight through it, and if you haven't, add a 40 amp fuse near the battery where your power cable is hooked up to. Also use a multimeter to test your power wire on amp, check the
Jul 19, 2013 | Car Audio & Video
I got a sony xm-460gtx amp I hooked it up in my truck everything was working fine then I disconnected the battery and reconnected it now there's power to the amp but no sound out of the amp???
If you are getting power the amp lights will be on k so I would check your coax cables and all hook ups to the amp. on some radios there is a sub control that will turn on your sub and to adjust your bass mine does the same thing when i disconnect power to the radio.
Oct 31, 2011 | Sony Car Audio & Video
The amp worked fine for about a year then one day the bass would not play through my subs properly sounding like a cd skipping only with the bass i would turn volume down and it would work fine until a...
When you hooked up your amp, did you hook it directly to the head unit so that it didn't come on with the car? Did you find the inline fuse in the amp positive cable? Few things to check..
Jul 13, 2017 | Kenwood KAC-6104D D Class Mono Power...
So, everything is hooked up, the amp is getting power, but the problem is getting power from the amp to the sub, any idea what the problem could be?
Well the two main things that i think of is that your fuse in your battery wire is blown. Or that your ground wire isn't all the way connected
Jan 18, 2010 | Alpine MRP-M500 Car Audio Amplifier
Ok everything is working but the remote wire not
First make sure you have the right wire hooked up, there is a Power Antenna wire, and remote turn on wire, and both are blue, but one has a white stripe.. Just make sure the right one is hooked up.
Now if the right wire is hooked up, and still no voltage there are 2 ways to get turn on power to the amp.
Option 1.
Buy a LVT (low voltage trip), they come with instructions, and arent very hard to use. They will only turn on the amp when signal is sensed through the speaker leads.
Option 2. (I don't care for this one)
Find an accessory fuse in the fuse box (meaning only has voltage when the key is in the on position), and run a wire from there directly to the amp.
WARNING ABOUT OPTION 2. This can be noisy, and cause a whine in your speakers, this should be a last option.
Aug 08, 2009 | Panasonic CQ-C8100U CD Player
When i connect my power wire to battery my deck cuts off and when i disconnect cd player works
This is your receiver going into speaker protection mode. this could be one of a couple of things based on what you have stated. The obvious would be that your amp is pushing too much power for your speakers. You can try a couple of things. 1st is check your watts for your amp and speakers and adjust your gain accordingly(may need to adjust how much your putting out). If it is turning off with the gain turned all the way down, then that's not the problem. Try disconnecting the RCA cables, then hook up to the battery and see if your amp comes on. If it does, you have everything hooked up right for the most part. Doing this will make sure your getting power to your amp.
If you get power with the RCA jacks unplugged, you might make sure that whatever speakers are hooked up to the amp are disconnected from the factory wiring. Those are some things to check based on what you wrote.. Could you be a little more specific with things like what kind of speakers and deck you have, how many speakers you are running, describe what happens when everything cuts off, etc.
Jul 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp wont turn on,, do i need to do something else
make sure that you have the fuse in for the 12 pos if you do then the only other way to check it to make sure the amp works is put a jumper wire from the positive to the remote on the amp and it should come on if it does the you need to find a fuse in the fuse block and hook it up to it so that the fuse turns it on with the key just make sure you use a multimeter and make sure the fuse turns on and off with the key
Jul 10, 2009 | Lanzar VIBE236 Car Audio Amplifier
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
Sony car cd player help!
Run a temporary direct power line to battery and see if it will turn on
Aug 08, 2008 | Sony Car Audio & Video
No light at all
A couple of things you can try:
1. check for B+12 on the 1st and 2nd terminals of the Power Connector using a voltmeter;
2. temporarily put a jumper on the 1st & 2nd terminal of the Power Connector;
3. the usual, check for loose connection, fuses, wires, connectors.
if there is +12 on both terminal and amp is still dead, then it is internal;
if there is +12 on terminal 2 but none on 1, then it is the wiring from the head unit or the trigger of the head unit that is the issue;
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 14, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Rockford Fosgate Punch 301S Car Audio Amplifier Logo
116 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
