Question about Car Audio & Video
95 ford probe wiring harness. no sound but turns on
My probe has a premium sound system with the square part on the harness
at first when i had my friend hook it up it played out sound and everything but then when he went to put in subs at a different time when he turned on the car the sound didn't work for some reason. Then I had a guy who works with cars for a living rehook it up with that stereo and his pioneer that he knew worked but still no sound. I've went to best buy 2 times now to figure out whats wrong and they told me to hook up the blue wires with the red and white. If you know of anything to try let me know.
and it's not the speaker because when you hook up the stock the sound comes out.
Hey I cant help you with your problem but can you help me? i have a 95 ford probe with a metal ended square harness on it, i went to canadian tire 100 times looking for the right harness and none fit it. a couple months later I had found another harness connector a few inches don't from the other square one.Now before i found that one i cut the harness and tried manually connecting them to the new radio. The radio would turn on but now sound would play.... and i tired 9 colour codes still nothing. if you have any idea about my problem it would be much appreciated thanks.
Posted on Dec 13, 2009
  • xxxscott15 Jan 01, 2011
    Okay the problem is that you probably have a factory amp , or a premium sound system from the ford factory. because of this the amplifier located either behind the passenger rear speaker or under the passenger seat you are unable to hear sound due to the amplifier. what you have to do is find the amplifier and buy a connecter for the wiring harness. the amplifier has to outputs and you can get a small adapter for it for like 10$ and wa la you should have sound. I hope this helps ;)
My 94 ford bronco has an odd wire harness that i cannot find a diagram for nor can i match any of the wire colors to any of the posted listings. the harness is small and square, for the speakers only
Your Bronco has the premium radio with separate amplifier. The harness you have connects the radio to the amplifier. The 8-pin connector is identified as follows:
RR (-) LT BLU
RR (+) PPL/WHT
RF (-) BRN
RF (+) WHT/RED
LR (-) YEL
LR (+) LT BLU/BLK
LF (-) WHT/ORG
LF (+) LT GRN
Apr 27, 2017 | Ford Cars & Trucks
Turn signal harness 2002 ford ranger 14a320 diagram turn signal connector wire colors and ppin location
images for Turn signal harness 2002 ford ranger
Ford explorer turn sinal problem got fixed - YouTube
? 3:23
www.youtube.com/watch?v=I2SUGIvYAWc
Jul 12, 2013 - Uploaded by Raybob216 My 04 exployer left turn signal and break light not working fix loose wires behind ... bulb and come to find out wire had popped out of the harness. ... How to Change Ford Explorer 2002 Flasher Relay for Hyper Flasher Relay ... How To Install Replace Turn Signal Wiper High Beam Switch Ford Ranger 95-98 ...
Oct 07, 2015 | Ford Cars & Trucks
Aftermarket stereo turns on but can't hear anything 1997 explorer
Did the truck have the premium sound system? If so, you will need to connect the blue remote wire to the blue remote wire on the harness. You may also need a special harness to bypass the factory amplifier.
Jan 10, 2014 | Car Audio & Video
I need to know if a distibuter from a 95 ford probe 4cyl will fit on a 95 probe v6
no it is incompatible and it would only have four wires when you'll need six.
Jul 07, 2010 | 1995 Ford Probe
I want to connect a trailer to my 95 probe SE the turn and brake lights are separate ,the turn is with the side lights any ideas?
they make a harness with revrse diodes so the current does not backflow , check with trailer supply house
Apr 28, 2010 | 1995 Ford Probe
Wiring for stereo in 94 ford explorer
Sounds like you have the Premium Sound system. The main power plug is long and probably black, the other plug is square with a grey round cord coming out correct?
You can either take your power harness back and get the correct one ( a little more expensive) or run ALL 4 sets of speaker wires back to the right rear quarter panel. That is were the OEM amp is mounted and taking that panel out requires you to remove the top and bottom tailgate trims, a dozen screws, the seat belt D-ring and 4-5 plastic push clips that will probably snap off...:( Also, this will not make the OEM subwoofer work.
From 20 years experiance in this biz, save the time, spend the extra 30$ or so and just buy the correct connector. Check MetraOnline.com and search there.
Scott
Apr 16, 2009 | Dual XDMR7710 CD Player
Trying to hook up aftermarket radio 98 windstar limited.
If this model has an amplified system, then you may need a different wiring harness. The harness you purchased may be for the non amplified model. Try that, and let us know.
Jan 29, 2009 | Metra Ford Premium Sound System Amplifier...
I have just purchase a clarion DB165 and i want to do the installation to a ford explorer 1994.
And.....what? You need a wire harness for the premium sound inteface. No kit needed as the opening for the factory radio is a DIN size. You'll know if it's premium sound by the factory plugs. One is wide and gray, the other is a small square metal one, the Non-Premium plugs are the same gray one and a similat black one (speakers) If the plus have been cut off, I can give you the Ford color codes.
Jan 24, 2009 | Car Audio & Video
Meter fuse 95 probe
you no doubt have a direct short in your wiring, or a bare hot wire is touching or rubbing a ground. check all wires that go to your meter. you don't say which meter it is. amp,water,oil,or battery.
Jun 27, 2008 | 1995 Ford Probe
Car Audio & Video Logo
404 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
