Question about Brother HL 5250DN Laser Printer
The Paper light keeps flashing when theres paper in the printer
  • 3 more comments
  • Anonymous Jul 02, 2008
    Paper light flashing, status light is red, paper in tray, will not print
  • printprobs Oct 26, 2008
    The printer seems to be having trouble recognizing there is paper in the tray.  Yep, I have paper in the tray and have thouroghly checked for paper jams, including the fuser tray.  The status light is red and the paper light is blinking yellow. I can get the printer to print directly, but not from the pc.  Here is the sequence I am doing:  I'm resetting the machine by disconnecting usb from printer.  Turn off machine,, turn back on while holding the go button.  After the amber status light goes out I hit the go button eight times.  The machine rollers come on, go off. Then I hit the go button 3x and the print settings pages print. Yeah!  I then reconnect printer to pc , go to printer properties and hit print a test page.  The status light turns red and the paper light blinks.  No test page prints. Boo!  How can this be fixed?
  • Anonymous Dec 15, 2008
    And I can't get it to clear
  • Anonymous Apr 14, 2009
    Neither of these solutions worked for me. Please help!
  • Anonymous Apr 16, 2009
    .. saying out of paper and there is paper in there ..
  • 58 Answers
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Posted on Dec 09, 2008
SOURCE: Help please. can't print: paper light flashing even though there is paper in printer
To fix the NON EXISTANT paper jam:
Status light is on, paper light is on - you can hear the paper feed trying to "grab" the paper, but it can't,  and status light goes Red.
Take out paper tray
Reset the blue paper holders, move them tight against the paper so the paper is snug against all blue barriers. Cause: Somehow the blue paper holders got dislodged and the paper is not snug so the feeder is trying to grab paper that  is slightly out of reach.
Posted on Oct 24, 2007
SOURCE: 3900 series printer
Same with mine and when I try to look for more jammed paper, there is none. I have wasted an hour messing with it and I tried to call HP and they want $65 to talk to me because my warranty is out of date. Someone, please help us!
Posted on Sep 21, 2008
jwildish
  • 22 Answers
SOURCE: paper light flashes red...
I found just doing this one simple thing sorted the problem.
First take off the front cover. Pull the tabs on the side. Pull out the big toner and cartridge. Do you see the blue tab on the top shaped like an arrow/triangle? Slide the tab from right to left - reinsert toner close door.
Hope it works for you
JPW
Posted on Oct 30, 2008
SOURCE: Paper light keeps blinking red
Pull out the drum. There is a blue button on it - if you pull it out and look straight down at it, it should be on the right hand side towards the printer. Slide the blue button back and forth, left to right, 20 times or so. Make sure to position it back to the right side all the way when done and put it back in. It should fix it. It is some kind of wire that is dirty with paper dust, etc. Brother told me to do that very thing when mine was having the same problem. Now, if that doesn't work, I also use the dust remover canned air and spray inside where the drum fits.
Hope it helps.
Posted on Nov 13, 2008
SOURCE: Flashing red light - no paper jam
I had this problem and couldn't figure out until I opened the front, pulled out the toner cartridge and found a paper jam.  Removed it and now I have the green light.
Posted on Nov 14, 2008
The orange light keeps flashing and it says there is a paper jam but I cleared the paper jam but the orange flashing light will not go off.
1. there is a sensor at the end of the printer which shows paper jam recovery. the sensor of your printer may be jammed. clear the jam and it will work. 2. if not, there may be a small piece of paper near the sensor of your printer. clear it.
Aug 30, 2011 | HP Deskjet 460c InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Orange light is flashing
I cleaned out the printer by removing any access toner. Made sure again no paper was stuck and then it worked.
Apr 14, 2009 | HP LaserJet 2100 Printer
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Mar 09, 2009 | HP DeskJet 845c Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Flashing paper light
there is a sensor maybe is stuck
Apr 06, 2008 | Brother HL-2070N Laser Printer
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Check paper light flashes, when paper loaded and no jam present
Might be a pending job gone wild. I would turn off the printer, then go to "Control Panel" and click "Printers". Double click the one you're having problem with, delete all printing documents and re-connect the printer.
You can also try a differnt USB cord or port, otherwise - the machine needs a factory reset.
Oct 22, 2007 | HP PSC 1610 All-In-One InkJet Printer
Brother HL 5250DN Laser Printer Logo
1,078 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
