Question about RCA HD52W59 HDTV Projection Television
Blinking power when power is plugged in the power button flashes a code of 59 & keeps repeating - any ideas?
POONANI
Posted on Jun 25, 2008
I have panasonic hdtv pt-59cl14 wont turn on when push power button the lamp light blinks red then the power button flashes yellow/orange 8 times then repeats . Any suggestions
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Dec 09, 2015 | Panasonic Televison & Video
My tv screen went blank and power light started to flash what could it be
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 04, 2015 | Samsung PN59D7000FF 59 In. Diagonal 1080p...
My Sony XBR KV-42DRC700 WEGA TV will not turn on. When I hit the power button, the red light flashes 10 times, and then repeatedly flashes 4 times with a 1-2 second interval between each 4 flash seque
Oct 19, 2014 | Televison & Video
What does it mean when the standby light flashes four times on a Sony TV Model # KV-24FV12 ?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 22, 2014 | Televison & Video
My samsung s125 keeps turning itself off
Aug 25, 2014 | Samsung Televison & Video
Why my Sony Wega tv standby light blinks 10 times?
Aug 23, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture but has sound
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Feb 06, 2014 | Sharp AQUOS LC60LE845U 60 inch 1080p 3D...
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn on
the rca itc222 chasis has no front led diagnositc codes. Does the led flash imedatly when you plug it up. or does it start when you push the power button. if it does when you first plug it in then you have a problems with what is know as standy voltages. voltages that are always there when you [lug the set in. the processor does not see correct voltages. now if this flashes occur when you oush power button then there is problems with the secondary voltages also known as run supplys. does the set try to turn on do you hear static.. if not then you might have high voltage flyback or horizontal output problems.
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
37 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
