Question about Brother LS-1217 Mechanical Sewing Machine
Treading the machine
I have a old brother the model number is vx581 and I don't have the instruction book and I don't know how to thread it PLEASE HELP!!!!!
  • whit86 Aug 24, 2008
    How do you thread the machine?
  • 323 Answers
All machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
sewman7
Posted on Jun 25, 2008
How do I stop my tread from popping on my Brother (17 stich) sewing machine?
Breaking thread? Presumably the top thread? AVOID old or bargain bin threads. The upper tension is too tight or the thread is not properly seated in the tension disk, the needle is defective or the needle, needle eye/scarf is not the best choice for the fabric/thread being used, there may be a snag in the bobbin area that is catching the thread. Make sure the thread is not catching on the spool's thread notch.
Why Does My Thread Keep Breaking While Sew
Sewing Machine Problem 1 Thread Breakage
Why is my thread breaking
Dec 07, 2016 | Brother Sewing Machines
Why Doesn't my sewing machine want to pick up the bobbin thread correctly?
if the bobbin case isn't turning properly are you sure you it in right.
Hold the lever on it out, slide the case on the spindle all the way and then release the lever. Also try a different length needle, it may be to long to allow a uniform stitch
Jul 12, 2014 | Brother CE8080PRW Limited Edition Project...
First time on Brother XL 2610, threaded correctly but thread will make loops and then pull apart. WHat went wrong?
try adjusting the upper tension
change the needle
if you recieved a instruction manual with the machine, look for the part that tells about what fabrics go with which needles, & the thread should move easily thru the needle eye with out any problem
Apr 12, 2012 | Brother XL-2610
We have an old! Brother sewing machine. We do not know how to thread it. Can you help us???
please send me a comment with the model number & I will try to help you
Oct 26, 2010 | Brother Sewing Machines
Threading brother mademoiselle 320 sewing machine
Call Brother at 1-877-276-8437 and see if they have something. Or you can look at www.sewingmanualsonline.com and look at the Mademoiselle 1243 model instruction book,, they have a download for that at $10. The picture may let you know if it would work. Good luck
Sep 21, 2010 | Brother LX3125 Sewing Machine
I bought a silvercrest overlocker and I am not able to thread one of the threads it has four threads
Kindly confirm the model number? Do you have an instruction book for the same?
Thanks!!
Jun 29, 2010 | Brother 1034D Mechanical Sewing Machine
Thread Breaks
Dear Sir / Madam, please get your book out and follow the threading instructions very carefully. I am certain that is your only problem.
Kindest Regards,
Cookey.
Jul 25, 2009 | Brother LS-1217 Mechanical Sewing Machine
How to thread my machine
I did not have a Serger, all I have is an old sewing maching but appeared to thread from the left slot and any machine that I have had always threaded from the right side. Anyway, I found a neighbor who was able to figure it out. I would love to get a directional book for the machine if that was possible. The machine is a Brother Model No. VX581.
Nov 15, 2008 | Brother Lay-In Thread Serger Mechanical...
I do not have a book of instructions with my sewing machineand I cannot figure out how to thread it. It is a demin sewlution.the model number is 408 i don't have a manual and i can't get mine to thread. i...
Go to www.brother-usa.com, and click on "Product Manuals" under "Support" on the menu on the left side of the page. You will need to select your model # from the pull-down menu, and then the manual will be available as a PDF download.
Oct 04, 2008 | Sewing Machines
Brother LS-1217 Mechanical Sewing Machine Logo
105 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
