Bearing have gone - Washing Machines
  • katherine11 Jun 25, 2008
    I have a LG front loader washing machine and the bearings have gone. How do i fix this?
    Genius:
  • 1,122 Answers
This is a big job requiring the removal of many major parts,i suggest you call in an appliance repair man,also the bearing kit alone cost around $200,thanks and let me know-mike
Posted on Jun 25, 2008
How to replace 2007 streetglide transmission output shaft bearing. Can it be done from thr left side?
Never had a transmission output shaft (the bearing that supports the belt pulley shaft) fail. Are you sure this bearing is gone? The bearing that usually fails is the clutch mainshaft bearing that is mounted on the inner primary casing and causes a noise that can be stopped by pulling in the clutch and putting it in gear. If this is the case, then the bearing is gone. It is replaced by removing all component from left side engine. No need to go near the transmission.
Feb 16, 2014 | 2007 Harley Davidson FLHX Street Glide
WBVH6240FWW loud bang
that would be the bearing and housing gone on the drum, if you can lift the drum with your fingers at the bottom of the drum in the door hatch even by putting lifting inside then the bearing has gone. the plastic is the drum.housing usually were the bearing housing is. if there is a lot of movement then the bearing has gone. usually the front bearing but you will need to remove the drum and separated the drum to remove the drum then the bearing, rust on clothing is the bearing as its the only part in the drum that is metal.
Jun 27, 2017 | GE WBVH6240F Front Load Washer
Bearings gone
If the bearing are gone, that is a good indicator of overall wear and tear, thus, I would recommend that you indeed cut your future losses and get a nice new unit with a warranty.
May 29, 2010 | Washing Machines
I have a aquarius hotpoint 340, bearing gone
You have to split the drum to replace the bearings
The reason the bearings have gone is that water has leaked into them and the soap content has destroyed the grease
There is a carbon seal on the spider assy which attaches to the back of the drum , this normally cracks so the spider or seal has to be replaced
Feb 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My machine bangs on a full spin.is it the drum bearing?its a hotpointwf340g.how do you replace bearing or fix this problem.
If it bangs it doesn't necessarily mean it is the bearing that is gone. It could just be a imbalance on the load inside. To check if bearings are gone open the door and at the rear of the door seal nearest the inner drum use your fingers to hold down the outer drum, will be at rear edge of seal, now use your other hand at the top pressing the inner drum edge and now press down on outer drum and up on inner drum. If bearings are gone her will be a lot of movement between the two. If no real evident movement then you can feel pretty sure it's not the bearings. Check suspension for signs of wear and check for loose weight block, also check for loose components inside the shell that may be hitting the outer drum. Could also be that the machine is unbalanced if the feet adjusters are not properly adjusted to level the machine correctly.
Feb 07, 2010 | Washing Machines
Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
OPENING CANISTER UP TO SEE IF BEARINGS OR MOTOR IS GONE
You really don't want to get into the vacuum. After you get in, there's not much that you can do other than look. If you really want to get in, there are two strips,one on each side of the cleaner under the rubber bumpers. The strips have to be removed by pulling off the bumper and pull them out the front of the vac.This is not easy. The bearings are not replaceable. If the armature is gone, you can have a armature and bracket kit installed instead of a new motor and save some money. The armature comes with the bearing pressed on the top.
Jan 07, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Washing Machines Logo
131 people viewed this question
Top Washing Machines Experts
