Question about Sharp AL 1631 Copier
Can not copy from tray/drawer, but get copy from multi-bypass tray
I can not get copies using paper from the tray/drawer, but still get copies from paper loaded in the multi-bypass tray. There are no codes shown on the operation panel. There is no paper jams. It looks like the feeder does not pick up the paper from the paper tray/drawer. Any suggestions?
  • 3 more comments
  • hsu888 Jun 25, 2008
    Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
    Yes, I'm using the letter size paper. Note this is not a scanner, it is just a copier.
  • dschmitz Jul 25, 2008
    I am having the same problem with my Sharp AL-1631 Copier. I can make copies using the by-Pass but not from the paper tray. Sounds like it is not picking up the paper.......hear some clicking but then the P light comes on. No jams......
  • Tim Babcock
    Tim Babcock May 11, 2010
    When you copy are you putting a letter size piece of paper in the scanner?
  • Tim Babcock
    What paper is in the tray?
  • Sharp Master
  • 2,794 Answers
You still have to scan the document before you copy it. I'm just trying to determine if something is going on with the automatic document feeder when you the images are being scanned.
It could be that the feed tires aren't picking up the paper but usually the jam light goes on if it cant pick them up.
One idea could be to reduce the amount of paper in the tray. Sometimes if it too full it can do this.
If that doesn't work, it should have a technician look at it to see what is causing the feed tires not to pick up the paper.
Posted on Jun 26, 2008
Posted on Jun 25, 2008
How do I make a copy using the bypass tray with card stock on the canon image runner 1310?
You have to select the paper tray(in this case bypass)when you make a copy.
Dec 10, 2014 | Canon imageRUNNER 1310 Printer
Image Faulty
there are paper guides on either side of the paper in the bypass.make sure thy are nice and snug right next to the paper.
Mar 07, 2014 | Kyocera Mita KM-1650 All-In-One Printer
I have a Panasonic Workio 1820 photocopier and I can't get it to copy A3 size documents. I have set the copy size to A3 but it will only copy and print an A4 portion of the document.
from where are u using the A3 paper . if ur using the drawer then simply select the original size and copy size as per ur requirement and first change the tray paper size to A3 in operator settings. if ur using by pass tray then be sure to pull the entire tray out as there is a sensor in the last end of the tray that senses A3 and legal paper
Aug 23, 2011 | Panasonic Office Equipment & Supplies
Sir I have canon IR2016J that some of days paper jam tray not working properly message shows paper jam open left cover but there no paper in machine.
first, do you copy from second drawer or bypass tray or first drawer?
Open the left door, in lower section open the paper cover. Now remove drawer. If You look from the left door side beneath the drum unit, you will see axis with 2 rollers, CLEAN them with alcohol or water by rubbing them, and dry them with dry cloth.
Also if you look little closer beneath the axis with rollers you will see the two rollers ( grey, one above the other ) clean them also or replace them if the rubber on them are too smooth.
If the problem appears when copy from second drawer, i.e. A3, you need to replace the pick-up clutch!
If the problem appears when copy from bypass, clean the bypass feed roller.
Hope that something of these helps you!
Mar 30, 2011 | Canon iR 2016i Black and White Copier
How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
NP6560 Main Specifications
Main Unit
Type: Console
Platen: Stationary
Photoconductive material: Amorphous Silicon
Copying system: Electrostatic transfer system
Developing system: Toner projection system
Fixing system: Heat roller system
Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
(However, Keep in mind that the paper weight that can be used varies
depending on the type of the Sorter being used.
SADF tray : transparencies and labels
Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
Maximum original size: 11" x 17"
Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
Non-image areas: Leading edge: 1/4" (4.5 mm)
Left and right side: 1/16" (3 mm)
Trailing edge: 1/16" (2 mm)
Warm-up time: Approx. 6 minutes (at temp. of 68°F)
First copy time: Max. 2.8 seconds
[LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
drawer) selected 1→1-sided mode]
Copy speed: Direct (100%) LTR 60 cpm
65 cpm (Accelerated mode)
LTRR 49 cpm
11"X 17" 30 cpm
LGL 40 cpm
STMT 60 cpm
STMTR 60 cpm
Reduction 11"x 17" → STMT 56 cpm (50%)
11"x 17" → LTR 48 cpm (64%)
11"x 17" → LGL 40 cpm (73%)
11"x 15" → LTR 48 cpm (73%)
LGL → LTR 49 cpm (78%)
Enlargement LGL → 11"x 17" 30 cpm (121%)
LTR → 11"x 17" 30 cpm (129%)
STMT → 11"x 17" 29 cpm (200%)
Magnification: Direct 1:1.000
Reduction 1:0.500 (11" x 17"→STMT)
1:0.647 (11" x 17"→LTR)
1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
1:0.786 (LGL→LTR)
Enlargement 1:1.214 (LGL→11" x 17")
1:1.294 (LTR→11" x 17")
1:2.000 (STMT→11" x 17")
Zoom 1:0.490-1:2.040
7-8
Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
Drawer 3, 4 (550 sheets x 2)
Stack bypass (50 sheets; stack approx. 1/4" high)
Multiple copies: 1-999
Power source: 120 V, 60 Hz
Max. power consumption: Less than 2.0 kW
Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
(1169 x 643 x 725 mm)
Installation Space (W x D): 40 5/8" x 28 1/2"
(1030 x 725 mm)
50 3/8" x 28 1/2" (1280 x 725 mm)
[With copy tray (option) attached and stack bypass auxiliary tray extended]
Weight: Approx. 462 lb (210 kg)
RDF (Standard equipment)
Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
11" x 17", LGL, LTRR, or STMT
15-lb to 32-lb bond (52 to 128 g/m2)
SADF tray: 11" x 17" to STMT
11-lb to 110-lb bond (38 to 200 g/m2)
Max. power consumption: 120 W
Original tray capacity: Original tray: 11" x 17" or LGL
50 sheets (20-lb bond or 80g/m2)
LTR, LTRR, or STMT
100 sheets (20-lb bond or 80g/m2)
1 sheet
Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
Power supply: 24 V (supplied from main unit)
Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
(174 x 643 x 539 mm)
Weight: Approx. 56.3 lb (25.5 kg)
These specifications are subject to change without notice.
8-1
ar
Energy Saver
Stop
Guide
Additional Functions
Start
Display Contrast
ii
Enter a ID number with the Number ( 1 - 0 )
keys.
MEMO: ? If you make a mistake entering an ID number, press
the C
Clear
key. Then, enter the ID number again.
? You cannot enter two identical ID numbers.
? If you enter and store "000000" in place of a current
ID number, that ID number is canceled.
? You can store up to 1,000 ID numbers.
Press the [OK] key.
If you want to store another ID number, repeat
steps 3 to 5.
5
After entering all the ID numbers to be stored,
press the ID key. The display returns to the ID
entry screen.
6
Canceling the ID Mode: Clearing All ID Numbers
If you clear all the ID numbers then you can make copies without having to enter an ID
number.
Press the Additional Functions , ID , Stop , and Additional Functions keys in that
1 order.
Clear
Guide
Interrupt
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
iii
Press the [OK] key.
MEMO: ? If you want to stop all the ID#s from being cleared,
press the [C] key.
Press the [CLEAR ALL ID#s] key.
Press the [STORE USER ID#] key, then press
the [OK] key.
All the ID#s are cleared.
If you press the [OK] key, you will return to the
Standard mode.
MEMO: ? Storing all the ID#s under "000000" will also clear all
the ID#s.
iv
In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
999,999). You can view the copy total for each ID number in the touch panel display.
1 order.
After pressing the [COPY TOTALS] key, press
2 the [OK] key.
Press the [?] or [?] key to check the copy totals
for a department. The copy totals can also be
displayed by entering the department number.
Press the Number keys ( 1 - 0 ) for a four digit
department number and it appears at the top of
the display. When you finish checking the copy
totals, press the [OK] key.
Copy Totals (Check Totals)
The following procedure describes how to clear the copy totals for all ID numbers to zero.
Copy Totals (Clear All Totals)
1 order.
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
v
2 the [OK] key.
Press the [CLEAR ALL TOTALS] key. 3
Press the [OK] key.
MEMO: ? To cancel clearing all totals, press the [C] key. 4
The copy totals for all ID numbers are cleared to
zero. If you press the [OK] key the display
requesting the entry of an ID number appears.
MEMO: ? You cannot clear the copy totals for ID numbers
individually.
Dec 21, 2010 | Canon NP 6551 Black and White Copier
No matching paper size set paper on bypass tray
Someone has told the machine to either make a copy or print from a PC to the Bypass feed tray on the copier. If you are not trying to print something by using the bypass tray then just turn the machine off, then on again to clear the request from the copier. If you are trying to print or copy from the bypass tray then simply insert the correct paper size and direction into the bypass tray slot and the machine should automatically begin printing.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Konica Minolta DiALTA Di200 Copier
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Oct 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
Printing crooked from one drawer, and no option to print from another drawer
Try this spray on a little WD40 on the GLASS and wipe it off.
Yes, you heard me correctly, make sure you wipe it off leaving no residue, but it's still slippery.
the problem may be coming from the glass being too dry and the paper is getting stuckand shifting.
If the paper itself was going crooked it would get jammed or ripped. There is no room for the paper to go through the path crooked so the only way for it to copy crooked is somewhere in the optics.
try doing 1-2 on the glass itself and see if it copies crooked.
The envelope tray is a By-pass tray and can be used for any size paper.You can switch which tray it copies from on the panel tray button.
Aug 28, 2008 | Canon imageRUNNER 2200
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
275 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
