If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
SOURCE: Washer Tub Fills With Water When Washer is Not On
I suspect you have a water inlet valve problem. When the valves fail, they tend to either leak by, or do not open at all. The symptom you are describing is typical of an inlet valve that is not closing properly. The leak may be minute, but over time, it fills the tub and over flows. To access the water inlet valve, you will need to remove the washer top panel. Remove the three screws in the back that hold the top in place and slide the panel straight back and lift off. The water inlet valve will be located on the left hand side in the rear between the fill hoses and the dispenser (as viewed from the front of the washer). If you wish to perform this repair yourself, you can find the part at searspartsdirect.com. Just type in your complete model number and the part can be located on the next page under the "Dispenser Parts" section as item number one (part #8181694). The replacement process is very simple. Just turn off the water source, remove the fill hoses, the dispenser hose and the mounting screws. If you need further assistance, please let me know. I hope this helps you.
SOURCE: My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
SOURCE: Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
SOURCE: WHDSR315DDWW, Fills then just sits there and hums.
Push down on the agitator. You may have to hold the activating button in with the lid up so you can do this. Press down firmly on the agitator and it should start rotating. If it does, you need to have it replaced. If it doesn't, then let the store know and they should take care of it. You should not put any money into since it is new. Anything you do from this point will cost you some money to fix.
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
