Question about Dell E171FPb 17" TFT LCD Flat Panel Monitor
E171Fpb driver on dimension 2400
I have just cleaned my hardrive on my dimension 2400. The monitor does not allow to change the screen resolution. I have tried to download the driver with no success. It just stores the file to my desktop and does not install the driver. Help
    Sergeant:
  • 233 Answers
Installing windows again then the monitor driver should resolve the problem
Posted on Jul 10, 2008
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
How do I fit the desktop to the full screen of the monitor?
before you change your screen resolution, you should know first the dimension of your monitor..
this is the common screen resolution for 22 inch LCD monitor: 1600 x 1024 1920 x 1080 up to 3840 x 2400
Note: You can only use this resolution if your video card supports this given screen resolutions. You can set your resolution through configuring the display setup.
May 26, 2011 | Emprex LM2201 22" LCD Monitor
My control panel will not allow me to change my monitor settings it is greyed out
your monitor cannot support in higher resulotion maybe plug & play your monitor during installation. Try install the proper monitor driver so that you can change higher resolution if not working maybe your monitor to old and can't support higher resulotion anymore
Feb 23, 2010 | Dell Dimension 2400 PC Desktop
I am working with Dimension 2400 with monitor 773c blank or no display, drivers load after safeboot, but I am not sure what to do from there, nothing happens when I push enter, but the monitor works with a...
Refresh Rate, the reason why it works in safe mode and not normal mode is because in safe mode the system only loads the most basic and reliable drivers and sets the screen resolution and rate to their default values. In safe mode right-click on the desktop and go to properties, go over to the tab Settings and click Advanced. You should see another tab that says Monitor, there you can change your Hz, change it to something like 60hz to be on the safe side.
Jan 27, 2010 | Dell Dimension 2400 PC Desktop
What is the biggest wide screen monitor can I get to use with the Dimension 2400 and the integrated video?
The monitor (19-inch, non-flat screen, 0.24 dot pitch) presented a more than acceptable image, even at its maximum supported resolution (1600X1200 @ 75Hz). We settled on a more reasonable 1280x1024 @ 85Hz as our preferred setting. According to the documentation, the recommended resolution is 1280x1024 @ 75Hz .Many of the newer LARGE monitors are limited to 60Hz and/or a larger dot pitch...So..look for a low dot pitch(below 0.27) and the ability to run at 1280X1024@75Hz . Passed that, the size is up to you.
Nov 18, 2009 | Dell Dimension 2400 PC Desktop
I clean my hard drive with wipedrive & put windows XP back in but can't change screen resolution,it's a dell 2400
install the video drivers - http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid
and after that try to change the resolution
If helped rate fixya
May 03, 2009 | Dell Dimension 2400 PC Desktop
USB ports and resolution failures
Reinstall your drivers you'll find them in your control panel
Apr 11, 2009 | Dell Dimension 2400 PC Desktop
Gmail page too wide
Dear Chuck:
I have a Dell Dimension 2400. Those came standard with a 15 inch monitor. Go to the blank screen, right click and click on properties, then click on settings, your resolution should be set to 1024 by 768. Or click on start, then click on control panel, double click on display, then click on settings, again your resolution should be set to 1024 by 768. If this does not solve your problem, then you need to find the correct video drivers for your monitor and download them.
Jan 08, 2009 | Dell Dimension 2400 PC Desktop
No power light and flickering screen
try to replace the cables first. if it that doesnt help then replace the monitor.
Sep 25, 2008 | Dell Dimension 2400 PC Desktop
Dell E171FPb 17" TFT LCD Flat Panel Monitor Logo
365 people viewed this question
Alun Cox
